What did you do to your connect today?
Re: What did you do to your connect today?
Postby Graham Taylor » Mon Mar 13, 2017 4:31 pm
Couple of mods done recently, Gaz struts fitted all around, side skirts and rear spoiler.
Oh and 20mm spacers fitted all round to fill arches more :-)
Graham Taylor
Postby Mc T » Tue Mar 14, 2017 5:23 am
Hi Graham, the rear spoiler looks very nice, is it a available model or did you make it your self?
Mc T
Postby Graham Taylor » Tue Mar 14, 2017 8:22 am
Mc T wrote:Hi Graham, the rear spoiler looks very nice, is it a available model or did you make it your self?
Side skirts and spoiler are made as a kit from someone one the transit connect-ed face book group.
Graham Taylor
Postby KempieConnect » Tue Mar 14, 2017 9:53 pm
Glued the door rubbers back on with Gorilla Glue after the hot glue gun failed
This is amazing stuff. It expands more than I expected and sticks like shit to a blanket.
KempieConnect
Postby mrtn » Sun Mar 19, 2017 12:48 am
Spring season's first serious wash, cabin cleaning and trim refreshening. The van has to be nice and clean to pick up alloys for summer tyres next week.
Now I read it'll start snowing again tomorrow.
1.6 Ecoboost LWB '16
1.8TDCi Tourneo Connect '12 (150 000 km)
mrtn
Postby mvirdee » Tue May 23, 2017 11:08 pm
Lowered my connect
T200 Limited 110
mvirdee
Postby u076216 » Tue May 23, 2017 11:17 pm
Ok, scharf ... oh eh sorry ... ok, hot :mrgreen:
Have a nice day.
Matthias
u076216
Postby marrigoshiy » Sun Jun 11, 2017 6:28 pm
um... Took a photo of the roof where there is what looks like stress fracture which is now letting buckets of water inside when it rains and starting to rust the anchor point. Got the sander and welder out and then it started raining so I went back inside.
I'd also like to ask if anyone knows... in the photo there is a line running the whole way along the channel in the roof that feels soft. This is obviously not a metal weld but a tape or some type of foam or rubber seal? If I sand away the paint I will inevitably cut into this as it is over part of the crack. What is it made of if I need to replace it? I've noticed its on the inside as well around the joins of the wheel arches and the floor.
Sorry, photo has come up sideways
03 Connect LXT220. First Car! work in progress.
marrigoshiy
Postby u076216 » Sun Jun 11, 2017 9:48 pm
In my opinion, this is not normal. Maybe someone try to fix the rust problem without success.
Have a nice day.
Matthias
u076216
Postby liteace » Mon Jun 12, 2017 10:37 pm
marrigoshiy wrote:um... Took a photo of the roof where there is what looks like stress fracture which is now letting buckets of water inside when it rains and starting to rust the anchor point. Got the sander and welder out and then it started raining so I went back inside.
Its seam sealer, it cracked with the heat, the cold, the movement of the van and water gets under it and then it starts to rot. As there no seam on the top side of the van this is where on both sides the roof panel joins
liteace
Postby liteace » Tue Jun 13, 2017 10:51 am
liteace
Postby travelling man » Sun Jun 18, 2017 2:39 pm
I made my windscreen washers work properly!
:D
I found that the filter/grommet thingy on the bottom of the tank was completely blocked up with gunge.
'05 Transit Connect T230 LX TDCi
travelling man
Postby growntree » Sun Sep 10, 2017 6:52 pm
Fixed the drivers electric window with the help of a £12 repair kit from eBay. :D
growntree
Postby mk2dk » Sun Sep 24, 2017 8:02 am
Hi.
Should have posted this yesterday, sorry.
Changed the alternator at 6:30 in the morning :(
Dog training started at 8:30 and we've got a 30 min ride to get there, which meant I was under pressure. It was a succes, the Connect is now charging the battery and the dog learned a little good behaviour :D
The old alternator suddenly let go, driving home from work. Had to turn off all electrics to avoid loosing to much battery power, and luckily made it home.
mk2dk
mk2dk
Postby patrick1962 » Sun Oct 01, 2017 10:20 pm
electric wrote:looks very nice :) which front springs have you used in the end
van looks good who lowered the back
patrick1962
