Radio problem
Radio problem
Postby kawatriple » Sat Aug 27, 2011 11:31 am
Hi i wonder if someone could help me please :)
I have a connect t230l 2008 fitted with a ford 6000cd
My problem is on the display "phone" keeps coming up, when this happens nothing will work, i can't even turn it off or on :(
cheers
ali
kawatriple
Re: Radio problem
Postby ake » Sat Sep 03, 2011 7:33 am
If you have the stereo code, disconnect it for a few hours, or disconnect the battery for a few hours to reset it
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Re: Radio problem
Postby kawatriple » Sat Sep 03, 2011 5:49 pm
Thanks for the reply, i did not get a code with my van.
Anybody know how i can abtain the code.
cheers
ali
kawatriple
Re: Radio problem
Postby Richard001 » Sat Sep 03, 2011 8:39 pm
You will need the serial number off the back of the radio if it starts with an M then post it here viewtopic.php?f=40&t=59769&p=810355&hilit=radio+code#p810355 if it starts with a V then you need to speak to Ford
2005 Transit Connect T230 LX, 90ps re-mapped (by vantuner), decat, EGR blanked,K&N air filter, HIDS upgrade, led sidelights, led fogs soon
2008 t230l connect works van
Richard001
Re: Radio problem
Postby kawatriple » Mon Sep 05, 2011 9:31 am
Richard001 wrote:You will need the serial number off the back of the radio if it starts with an M then post it here viewtopic.php?f=40&t=59769&p=810355&hilit=radio+code#p810355 if it starts with a V then you need to speak to Ford
Thanks for that, i have just ordered the 4 keys to get it out :)
kawatriple
Re: Radio problem
Postby taz666 » Mon Sep 05, 2011 10:13 pm
i can get v codes but will need the part number and serial number off the unit
taz666
Ford Technician
Re: Radio problem
Postby kawatriple » Thu Sep 08, 2011 3:45 pm
Hi just got the unit out :shock:
the part no. is 6S61-18C815-AJ
serial no. V396946
Thanks very much
ali
kawatriple
Re: Radio problem
Postby kawatriple » Thu Sep 08, 2011 7:00 pm
Thanks everyone for your help :) and Kevin for the code.
:( but alas it's still got the fault, so looks like ebay for a 2nd hand one
regards
ali
kawatriple
Re: Radio problem
Postby taz666 » Thu Sep 08, 2011 7:14 pm
what phone are you using???
taz666
Ford Technician
Re: Radio problem
Postby kawatriple » Thu Sep 08, 2011 7:24 pm
I phone 4 with blue tooth turned off
kawatriple
Re: Radio problem
Postby gt_addict » Thu Sep 08, 2011 7:35 pm
Ok this might sound dumb but have you pressed the phone button on the face? Have you switched off your bluetooth on your phone?
gt_addict
Re: Radio problem
Postby kawatriple » Thu Sep 08, 2011 7:44 pm
Hi, yes i have pressed the phone button many times and the blue tooth on the i phone is turned off
kawatriple
Re: Radio problem
Postby gt_addict » Thu Sep 08, 2011 8:09 pm
kawatriple wrote:Hi, yes i have pressed the phone button many times and the blue tooth on the i phone is turned off
I wasn't having a pop at your intelligence, it just hadn't been suggested ;) I hope you get it sorted without too much aggravation :)
gt_addict
Re: Radio problem
Postby kawatriple » Fri Sep 09, 2011 7:37 am
Any advice is good, it might help someone else :)
i keep thinking it might be dover customs fault, it was never the same when they ripped my van apart :( all because i could not remmber the little town in germany i went to :oops:
kawatriple
