Can you remove door lock barrels without a key
Postby david106 » Fri Oct 28, 2011 8:58 pm
I did a search and it came up about drilling them out but i dont want to go to that so is it possible to remove the barrels without a key
many thanks
david106
Re: Can you remove door lock barrels without a key
Postby L200Lee » Fri Oct 28, 2011 9:15 pm
im sure there is a way, but dont think people would be quite too keen to broadcast it over a forum.
:roll: :lol: :lol:
I like to think This forum was a boring place until I turned up!
L200Lee
Postby Tuug » Fri Oct 28, 2011 9:18 pm
Are you saying you cant get in the van doors locked lost keys ?
Tuug
Postby david106 » Sat Oct 29, 2011 12:44 pm
Hi
yes bought van and it has had a couple of lock changes and was given a bunch of keys and none of them fit the front doors .
ok its got remote locking which now works correctly after finding the problem and on visiting a breakers yard to remove the latch assembly from a connect i discover that the only way i could see to remove the barrel was to insert the key .
Now i would like at least one of the door barrels matching my ignition key so in the event of the central locking failing i could still gain access to the cab.
If anyone does know how could they pm me
thanks
david106
Postby Dagenham Dustbin » Sat Oct 29, 2011 11:28 pm
Do any of the keys actualy turn in the lock, even though it wont unlock it, as you only have to turn the key in the lock barrel 90 degrees to release the pin.
Dagenham Dustbin
Postby winterheating » Sat Oct 29, 2011 11:52 pm
Your best bet is to get as many ford keys as you can, friends,family,scrap cars. and should be able to get one of them to turn the lock, maybe a bit stiff but should do it.
winterheating
Postby Tuug » Sun Oct 30, 2011 9:06 pm
just get a locksmith it will take him 2 minutes to work out what key you need cutting .... ...
Tuug
Postby winterheating » Sun Oct 30, 2011 9:12 pm
Tuug wrote:just get a locksmith it will take him 2 minutes to work out what key you need cutting .... ...
From what he won't have anything to go off?
Unless he has a pick, that will work it to get lock out?..
winterheating
Postby Tuug » Sun Oct 30, 2011 9:24 pm
He has a piece of kit that will tell him the code needed to cut a key for the lock
Depends what the guy wants easier to get keys cut i would think
Tuug
Postby david106 » Tue Nov 15, 2011 2:24 pm
getting some keys cut would be great i ended up getting a new door latch assembly $$$$ the old lock was mullered to get it out and i have a blank over the hole but i still need a barrel for drivers side.
david106
