Turbo Problem??
Turbo Problem??
Postby connectmac » Tue Nov 08, 2011 9:56 pm
Hi Guys.
I have an issue with what i think could be a dead turbo. I have had the van only about a month a gradually the turbo wistle has become louder. The van has always smoked like hell when you floor it. Today while driving the van suddenly became very slow with no turbo boost at all (No engine light or anything). I can not hear the turbo spool anymore. With working long hours i have not had any time to have a good look. I was going to be blanking egr and de-catting when i eventually get a day off.
Anyone have any other ideas :?: Bloody undriveable at the min :(
connectmac
Re: Turbo Problem??
Postby Wobby » Tue Nov 08, 2011 9:58 pm
Might be worth providing a bit more info on engine (tddi tdci etc), age, mileage.
Wobby
Re: Turbo Problem??
Postby connectmac » Wed Nov 09, 2011 9:18 pm
Hi. Its a 2006 tddi with 102k. Ex rental company van with full service but prob been thrashed
connectmac
Re: Turbo Problem??
Postby g-man » Wed Nov 09, 2011 9:55 pm
when was it serviced,check air filter,then take off boost pipe to egr valve and get someone to rev engine,see if u can feel airflow increasing
g-man
Re: Turbo Problem??
Postby connectmac » Wed Nov 09, 2011 10:21 pm
Thanks g-man. It was last serviced in august this year mate
connectmac
Re: Turbo Problem??
Postby Kent Discos » Fri Nov 11, 2011 8:52 pm
check all piping before assuming turbo has gone....
was the smoke black or white?
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Re: Turbo Problem??
Postby Wobby » Sat Nov 12, 2011 12:58 am
Kent Discos wrote:check all piping before assuming turbo has gone....
Or blue? :D
Wobby
Re: Turbo Problem??
Postby Kent Discos » Sat Nov 12, 2011 7:53 pm
any colour will do :lol:
Kent Discos
Re: Turbo Problem??
Postby connectmac » Sat Nov 12, 2011 8:01 pm
Black smoke guys. Had the van plugged in to read codes and it come up with P0235 turbo charger boost sensor A circuit. Ive checked all pipework, cleaned pipes and checked air filter. Could it be the map sensor? Turbo sound before i lost power didnt sound to well :(
connectmac
Re: Turbo Problem??
Postby taz666 » Sat Nov 12, 2011 8:41 pm
take the pipe from the air filter to the turbo off and get your fingers into the inlet side of the turbo, grab the shaft and see if there is any up-down, side to side movement, only a very very small amount is permissable :!: :!: , if you can get a small mirror in there and check for any impellor contact with the outer casing
taz666
Ford Technician
Re: Turbo Problem??
Postby connectmac » Sat Nov 12, 2011 9:00 pm
Cheers taz i will check that in the morning
connectmac
Re: Turbo Problem??
Postby connectmac » Sun Nov 13, 2011 3:49 pm
Just an update guys. I had the van on ramps this morning and noticed that the turbo actuator rod had come away from the manifold. The fixing bolt had snapped. Goin into garage tomorrow to get it sorted, going to be a lot cheaper than i was expecting :D
connectmac
Re: Turbo Problem??
Postby shaiboyuk » Wed Nov 23, 2011 11:40 pm
Hi connectmac,
How did you get on with this? I have a 2006 TDDI with the same issues :(
Hope it something easy for me too :)
Cheers
Shaiboyuk
shaiboyuk
Turbo Problem??
Postby shaiboyuk » Thu Nov 24, 2011 4:50 pm
Hi again,
Checked mine out today and found the rod had snapped off at the end, to the arm :/ can't see an easy way to fix it back onto the arm :'(
See photo below:
Let me know how you get on connectmac
Cheers
Shaiboyuk
shaiboyuk
Re: Turbo Problem??
Postby ytboi2006 » Wed Mar 28, 2012 4:57 pm
HI I have a similar problem with my van apart from you can still hear the turbo on mine but it's got no power, the more you rev the engine louder the turbo noise is but has no power. Oh and mine is a 2005 tdci. I would appreciate any help thanks guys.
ytboi2006
