Leeday wrote:"Lock stripping and re-building, this service is for anyone who has an odd lock on their vehicle which doesn't match. An example is ignition barrel has been replaced, so you now have a key for the ignition and a different key for the doors. I can re-tumble the ignition barrel to the same pattern as the door key, cut a replacement key and fit your programmed transponder from the old ignition key into the new key. You now have one key that fits all the locks."
Hi bancroftlocksmiths
On my Mk3 I have 1 key for drivers door and ignition, another key for passenger door and side loading doors, and another key for the tailgateHow much £££ would it be to get all locks working off of 1 key, as I walk with a limp when all these keys are in my pocket
I'll take a look at your keys and locks and see what would be the best way to go on this one. Might have a couple of options for you.
mmmmm
