Leaking oil filter cap.
Postby transbenny » Wed Nov 29, 2017 3:55 pm
So I took my van in to have a recall done (oil pump, Dec last year) Evans rang me up saying you need this and that, that be hundreds of pounds please. I wasn't happy at all! New sump,new oil filter cap. So I went off and purchased these bits. Evans then fitted them but I now have a leak on the join from oil cap to pump. No point going to Evans as I brought these bits and they fitted when they did the recall..
All the parts where brand new. I've tightened it as much as I can, my question is how the he'll is it leaking. I've just undone it and tightened it up again but Ive not got much hope.
Shall I just buy another cap and see if that's works by swapping them? Oils done less than a 1000 bloody miles.
Cheers chaps.
Transit 330 euro5 2.2 first owned tranny after driving works one for 20 years, love it so far...
transbenny
Re: Leaking oil filter cap.
Postby transbenny » Wed Nov 29, 2017 3:57 pm
Pick of the leak.
transbenny
Postby Howey1990 » Wed Dec 20, 2017 3:14 pm
Probably the o ring maby been niped when put on probably been put on dry or its in the wrong groove
Howey1990
Postby Howey1990 » Wed Dec 20, 2017 3:19 pm
And you dont need a new sump lol iv done well over 500 of these in recalls iv seen me do 7 8 aday at one point ya only need oil pump kit what is the pump its self and banjo bolt filter and sumps sealer and then you get the oil there is deffo no sump needed
Howey1990
Postby knobby1 » Wed Dec 20, 2017 7:38 pm
Howey1990 wrote:Probably the o ring in the wrong groove
+1..^^ We've seen this before.
And the pump is actually inside the engine, the sump is removed to get at it, it's not part of the filter housing....maybe your garage damaged the sump trying to remove it??
We've had some sumps that are porous too...not a lot but it does happen.
Postby Howey1990 » Wed Dec 20, 2017 7:47 pm
If it is in the wrong grove note it would be pissing out and not just a slight leak
Howey1990
Postby knobby1 » Wed Dec 20, 2017 8:01 pm
Howey1990 wrote:If it is in the wrong grove note it would be pissing out and not just a slight leak
Yeah, you're right....there's a small hole/slot in the grove above the normal "O" ring groove isn't there..? I think it's there to help drain the cap while removing it.
Postby Howey1990 » Wed Dec 20, 2017 11:30 pm
Yep they do
Howey1990
