Spring Hanger back chassis section has moved when I cut out the back panel (oh bugger), I have included photo's. The question is should the spring hangers be slightly higher as the other side which has not moved is or should they all be consistently flat. I am going to remove the spring tomorrow to do some rectification on this - so any information would be kindly appreciated.
regards Mark
Here is the amount it has moved on the right hand side:
Here is the left hand side ( note still slightly higher but not like the moved right hand side spring hanger:
Here are some general pics of today's progress:
