Double Bed From Roof...
Postby JBOZ » Thu Feb 02, 2012 12:04 pm
I am in the search of a mid roof transit so that I will be able to drive to race events and roadtrips ect. So I am thinking, would to be possible to make a cradle for a double be and have it so when not in use it can go up and sit in the mid roof section. how would be the best way to secure? Thoughts, ideas?
Thanks James :)
JBOZ
Re: Double Bed From Roof...
Postby Beegly » Thu Feb 02, 2012 2:58 pm
It`s been done, and there are pics on here somewhere
Mondeo 130 TDCI - personal use
30t mobile crane - for work
2004 T280 125 TDCI, 183,000 miles. sold
'96 Citroën ax, 58ps. saved me over £1500 in diesel. SOLD, replaced with
2001 Citroen saxo 1.5 d
Beegly
Postby transitandy » Sat Feb 04, 2012 12:33 am
Hi i think mattblackminibus has done it :?: welcome to the site aswell m8y :)
Postby northernlad » Sun Feb 05, 2012 7:13 pm
The device you are looking for can be bought in a kit form from an Italian company called STLA, the UK distributor is called Scan Terieur.
northernlad
Postby ovrkll » Tue May 08, 2012 11:23 am
Do you know where i can buy it?
ovrkll
Postby andy 63 » Tue May 08, 2012 10:43 pm
ive not seen what you want done but as others have said it will have been . dont know if bunks are a possibility for you. if they are heres some pics of my effort at putting them in. not got the foam for mattress yet but im hopeing by the end of this week that should be sorted. the top bunk swings down to form a back to the bottom one for a seating area when required. ta andy
the basic framework
the top bunk swung down
andy 63
Postby ajpmsport » Wed May 09, 2012 11:05 pm
JBOZ wrote:I am in the search of a mid roof transit so that I will be able to drive to race events and roadtrips ect. So I am thinking, would to be possible to make a cradle for a double be and have it so when not in use it can go up and sit in the mid roof section. how would be the best way to secure? Thoughts, ideas?
Thanks James :)
:idea: I`ve had this crazy idea going round and round. I will try and explain it the best way i can. Two garage door mechanisms, i`m sure it will work and will be pritty cool. Always a but........it really needs to be a high top, but i`m sure a mid roof might be ok.
Two spring boxs like this, one at either end mounted in the roof of the van flat. The spring box has two springs in so when you open the garage door cables pull the springs so they stretch.
The cables go round a pulley which could be mounted on the corner of the roof of the van.
and down to a spindle. These spindles would be fixed to four corners of the bed and run in 4 guides which would be fixed to the side of the van.
The spring box will have to be shortened and layed flat in the roof. The runners will have to be shortened and let into the side of the van.The cables will have to be re-crimped shorter.
The bed could be a large wooden square frame ply lined both sides strong enough to take two people (or two domestic light as possible ply lined doors fixed together). At night pull the bed down and have a latch to click into place. It could come down and sit on a deviding low bulk head partition with a hinged or sliding "gate".
In the morning un latch and the bed will go up into the roof already made for the next night.
This will allow a work type station in the rear of the van whith not to bad head room during the day (hopefully). If you had a bike it could be made to just come down on top.
Hope this makes sense, i drew a sketch.
A= Bulk head where the bed sits on.
B= Sliding or hinged door (could be used when the bed is up
C= The bed platform.
1= Bed down.
2= Bed up.
hope it comes out. :P
ajpmsport
Postby ajpmsport » Thu May 10, 2012 1:37 pm
Sorry, the first paragraph should read. "when the garage door is CLOSED the cables pull the springs so they are stretched.
THANKS
ajpmsport
Postby andy 63 » Thu May 10, 2012 9:44 pm
hi ajpmsport, cool idea as you said. does the difference in width of the van at roof level and where the bed sits in use cause any problems with locating runners for the mechanism. ta andy
andy 63
Postby jolly olly » Thu May 10, 2012 10:40 pm
Did you get sorted for your foam?
As there is a place at Fence House's that sell's to the public (i think) im not sure on the turn around time though it could be upto 10 day's, give me a shout if you need more info and i will see what i can dig up cheers.
Life is not a dress rehearsal
jolly olly
Postby ajpmsport » Thu May 10, 2012 11:28 pm
andy 63 wrote:hi ajpmsport, cool idea as you said. does the difference in width of the van at roof level and where the bed sits in use cause any problems with locating runners for the mechanism. ta andy
The runners would have to be vertical all the way. As you say the narrowist part is at the top so this would govern the bed base.
It does not have to be garage door runners or spindles realy so long as their strong enough to take the cable and spring.
I did have a thought of having the runners on the angle on the wall of the van. When the bed is pulled down the spindles follow the line of the runner and the bed has sliders in the middle so it can go wider. I think the difference was about 340mm. Getting complicated though. B and Q sell a wardrobe runner and roller kit which might do this.
I based the gear on a Garador mk3 or 3c anything like this. Ebay had a second hand door near me free to collector, providing its got all the running gear, jobs a gooden !
The spring boxs are marked up with a PN numbers with a blue or silver band, these relate to the size of door. As long as these are paired up simular( you would not want a 7` wide springs one side and 14` springs the other)
ALSO if you do play with the springs beware of the recoil if you let one go it will take all your fingers off !
I will try and run the tape round the van to get some measurements and an idea of head room.
Here are the parts new to get a better idea :wink: I will stop waffling now.(i did all this once and didnt save it and wiped it all off, excuse my spelling by the way).
cables
http://www.ebay.co.uk/itm/GARADOR-Mk3c- ... 1c232cd58b
spindles (they come in different lenghts)
http://www.ebay.co.uk/itm/GARADOR-MK3C- ... 19d0736992
spring box
http://www.ebay.co.uk/itm/Garador-Sprin ... 1c139e0455
THANKS
ajpmsport
Postby transitandy » Fri May 11, 2012 12:02 am
Thanks James :)
Did you get sorted then m8y :?:
Postby transitandy » Fri May 11, 2012 12:07 am
andy 63 wrote:ive not seen what you want done but as others have said it will have been . dont know if bunks are a possibility for you. if they are heres some pics of my effort at putting them in. not got the foam for mattress yet but im hopeing by the end of this week that should be sorted. the top bunk swings down to form a back to the bottom one for a seating area when required. ta andy
the basic framework
Thats a good idea m8y :)
Postby andy 63 » Fri May 11, 2012 11:35 am
joly joly, thanks for info. i know the place you are on about. got foam from there for last van. ive got a lad in blaydon doing me some covers and he supplies the foam as well (could be from same place :) ) thanks again
ta transitandy, my effort is fairly basic compared to what is been mentioned above. dont think transits are the easiest vehicle to convert. the body slopes all over :roll:
ajpmsport, ill look at your links tonight when ive got the time. i just cant visualise the job because i dont know how the mechanism works, how much room it will take up etc. if it was me id be looking for an easier simpler option lol :lol: good luck if you go ahead.
ta andy
andy 63
Postby Bill in Transit » Wed May 23, 2012 6:00 pm
Hi, have you considered a hammock? You'll save space, weight, effort and money. A descent quality one can be comfortable and you'll soon get use to it.
1991 ('92 Reg) Mk3 190 LWB Dormobile (ex.10 seater bus) now camper conversion,
with 1999 2.5 lt TD 100PS engine, Bosch 146 pump.
Bill in Transit
