Tony's MWB Camper Convesion
Re: Tony's MWB Camper Convesion
Postby tonylem » Sun Mar 10, 2013 8:54 pm
Not as much progress this week as I had hoped, but got a bit done,
Bit more lining in
And got a start on the kitchen units
Think this layout should work OK, as still want access to back door. Also leaves just short of 1.9 meters length and the full width for the bed, so should be able to squeeze in a shade short of a full sized double, and still just be able to move round the van with the bed out.
Also had a motorway speed run in the pissing rain and was pleased no water came in the mushroom roof vents. Very slight amount of wind noise at around 70-75, but nothing major. Hopefully once I get the roof lining finished and a grille over the top they should be quiet.
2008 Mk7 MWB 140 T280 High Roof
tonylem
Postby robbie.cee » Sun Mar 10, 2013 9:07 pm
bloody good show so far m8 top work, keep those piccies coming! proper job! 8) nice motor too! :mrgreen:
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby tonylem » Sun Mar 10, 2013 9:13 pm
Cheers Robbie, just trying to take my time a little and do a better job, rather than ploughing ahead. But on the other hand, I'm impatient and want it done :)
tonylem
Postby tonylem » Sun Mar 17, 2013 5:05 pm
Seem to be at the stage where you do shed loads of graft and don't seem to have done much!
Got the hook up electrics in
And got a bit more lining done,and got a start on the overhead lockers
Slowly starting to look like something :)
tonylem
Postby robbie.cee » Sun Mar 17, 2013 8:43 pm
m8 how is the rockwool still up on rof in piccy, what magic did you pull to get it to stay up- cant see string or owt?! :P
that floor should also keep road noise down quite considerably! :wink:
Had
MAKE IT FIT
robbie.cee
Postby tonylem » Sun Mar 17, 2013 8:50 pm
Robbie, it's quite easy, just turn the van upside down :lol: :lol:
Actually a quick spray with carpet adhesive, and just stick it up. Works great. It's starting to get noticeably quieter as I get more insulation and lining fitted.
tonylem
Postby robbie.cee » Sun Mar 17, 2013 9:10 pm
Genius!! ill try that meself ! :D tried using polystyrene up top between spars... not good , love rockwool and still have a third of a roll/pack so ill make good use of it!!!
keep up the great work m8 !! 8)
Had
MAKE IT FIT
robbie.cee
Postby transittucker » Tue Mar 19, 2013 11:29 pm
this is a great conversion. Top job. Whats the thickness of the rockwall? Thinking of using that myself......
transittucker
Postby tonylem » Wed Mar 20, 2013 8:39 am
TransitTucker, the rockwool is whatever the thickness of the void behind the ply is, so anywhere from about an inch to up to 3-4 inches in places. If you want more insulation, whatever type you use, you will have to add battens to the body to increase the depth of the void.
tonylem
Postby tonylem » Sun Mar 24, 2013 5:14 pm
The forecast blizzards never turned up, so got a bit done today. Bloody freezing though.
Finished off the overhead lockers with the doors,
Also lined the inside of the over cab locker. Bit of a bitch to do, and not the tidiest of jobs, but it will be inside the cupboard, so wont be seen too closely,
Roll on some warm spring weather so I can really get cracking.
tonylem
Postby bezzabsa » Mon Mar 25, 2013 7:04 pm
Nice!!!! going to be a tidy little camper there when its finished.., you adding an awning later?
Driving a Transit estate...Mondeo 130 Tdci 2002 ;)
Yam Yam from yamyam land ayit ??
Bostin' ay it?
bezzabsa
Postby tonylem » Mon Mar 25, 2013 7:23 pm
Might add an awning at some point, when funds allow, so it may be a while :lol:
tonylem
Postby tonylem » Thu Mar 28, 2013 3:56 pm
Overcab locker coming together. You don't realise how big a space that is until you box it in. It's a mahoosive cupboard, I'm sure a short arse like me could climb in and use it as a bunk :lol: :lol:
Hopefully now can get the last bits of lining finished at the weekend.
tonylem
Postby tonylem » Sat Mar 30, 2013 6:23 pm
Finally got the bulk of the lining finished, with a neat little door to close to mushroom roof vent off when driving, as it makes a bit of wind noise
Then started on a bit of electrics by putting in the switches for the over hob lights and fan
And finished
They even light up when on :D
tonylem
Postby tonylem » Sun Mar 31, 2013 4:14 pm
Started on the frame for some more overhead lockers, and put the last bit of carpet on the edges of the B pillars
tonylem
