Tony's MWB Camper Convesion
Re: Tony's MWB Camper Convesion
Postby Honey monster » Sun Apr 21, 2013 7:47 pm
what paint are you using on the MDF ??
Honey monster
Postby tonylem » Mon Apr 22, 2013 7:28 am
It's Dulux Satinwood, the waterbased colour mixing one. Needs thinning quite a bit but gives a decent finish and seems pretty tough. Time will tell how hard wearing it is.
2008 Mk7 MWB 140 T280 High Roof
tonylem
Postby suffolkboi » Mon Apr 22, 2013 10:25 pm
What vent did you use to allow a narrow pipe to be fitted?
Do you plan on making the cupboard air tight?
Mk5 Camper build - Work in progress
viewtopic.php?f=58&t=104595
suffolkboi
Postby tonylem » Tue Apr 23, 2013 8:08 am
Yes the cupboard will be getting a door on. The vent itself is a piece of 40mm solvent weld waste pipe. Fits snugly in a 44mm hole cut with the holesaw.
tonylem
Postby tonylem » Sun Apr 28, 2013 2:53 pm
Bed base and cushions sorted. Just need to properly upholster the cushions and it should look spot on.
Will try and get some flooring down next.
tonylem
Postby Honey monster » Sun Apr 28, 2013 3:24 pm
Nearly there now mate, Mattress work looks top notch.
What flooring are you going for??
Honey monster
Postby tonylem » Sun Apr 28, 2013 3:32 pm
Yes, nearly there. Just a few bits of finishing off. Although these things are never finished, will always be fiddling with things :lol: :lol: But at least it's usable now :D
Not sure of flooring yet, but my parents have a piece of left over carpet that will fit, so might just stick that in for now.
tonylem
Postby tonylem » Mon May 13, 2013 2:49 pm
Couple of more bits of finishing off done,
Put a bulkhead/cushion support in and carpeted the bed frame. Also put some carpet down as a temporary flooring (it was free, so will do until we get some proper flooring).
Door put on gas locker and water and waste plumbed in
Just need to sort a table out then it should be ready for DVLA reclassification. Starting to look finished though, and once the cushions are upholstered I will be well pleased :D
tonylem
Postby tonylem » Tue Jun 25, 2013 12:50 pm
Finally got the built in cool box completed, works a treat,
Also got the reclassification done with DVLA. No problems, got the new V5 back within 2 weeks. No graphics or decals on either!
tonylem
Postby suffolkboi » Tue Jun 25, 2013 5:11 pm
Nice one!
Was this reclassified by photos only?
suffolkboi
Postby tonylem » Tue Jun 25, 2013 5:23 pm
Yes, just sent a bunch of photos showing all the required bits (bed, hob, sink, table etc), the V5 with motor caravan as the new body type and a covering letter. Took a couple of weeks and they even sent my photos back. :D
tonylem
Postby donjo tranvan » Thu Jun 27, 2013 1:40 pm
loving the van. going to do the same with the v5, what did you put in your letter to dvla
a transit is for life not just the weekends
donjo tranvan
Postby tonylem » Thu Jun 27, 2013 2:23 pm
Donjo, letter doesn't need to be anything special, just a request to change of body type of vehicle to motor caravan, together with a brief explanation of work done and parts fitted. Add a list of the pictures you are sending, with a brief explanation of what each one shows. Send enough pictures as you need to show everything done, and make sure you can see the reg number in at least 2 or 3.
Then fill in the change request section on your V5c (section 7 - wheelplan/body type to Motor Caravan), and send them all to the DVLA in Swansea.
tonylem
Postby suffolkboi » Thu Jun 27, 2013 5:08 pm
What benifits does this bring? Will it make a class 7 become a class 5 for MOT?
suffolkboi
Postby tonylem » Thu Jun 27, 2013 5:51 pm
Insurance tends to be easier, not necessarily cheaper, but in the event of a total loss, saves a lot of problems. Hopefully it won't happen again, but when our previous converted van was written off, we had a right chew on with the underwriter/assessor as they saw it as just a panel van.
I believe it does reduce the MOT class on a class 7, but is dependant on weight, but I am not sure on that one.
You also get normal car speed limits on A roads and dual carriageways, as long as gross unladen weight is under 3T.
tonylem
