1978 mk 1 camper
1978 mk 1 camper
Postby walt1984 » Tue Sep 04, 2012 9:16 pm
hi, decieded to try and post pics of our mk 1 transit CI camper van.
bought earlier this year and started doing little bits to it.
(if i've done the photobucket right there should be a pic of it)
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Re: 1978 mk 1 camper
Postby silverfox25 » Tue Sep 04, 2012 9:22 pm
Nice van Walt 8) 8) :)
silverfox25
Postby walt1984 » Tue Sep 04, 2012 9:28 pm
started by giving the engine bay a clean up and fitting a accuspark ignition, new plugs, leads, dizzy cap, roter arm.
had to get me dad to show me how to go about timing with a dizzy as i.m used to fiestas with coil packs and injection.
walt1984
Postby montym100 » Tue Sep 04, 2012 9:41 pm
Looks in very nice condition 8)
montym100
Postby walt1984 » Tue Sep 04, 2012 9:45 pm
thanks.
just trying to add more photos but i dont know where they went :?
walt1984
Postby walt1984 » Tue Sep 04, 2012 9:57 pm
wanted to flush cooling system and change stat but snapped a bolt head off. i don't have a pic of me dad with a lead welding torch warming bolt up i think i was more worried about something catching fire!
when me dad drive it back from essex he said water temp was erratic and heater was hot and cold ( i was nearly asleep following in connect at 50mph all way back to west yorkshire) this is what we drained out .
walt1984
Postby jonochap » Tue Sep 04, 2012 10:00 pm
Awww, that looks way cool! Nice colour gunk though :)
Owner of not so troubled puk :)
jonochap
Postby walt1984 » Tue Sep 04, 2012 10:16 pm
looking abit cleaner.
got hold of some new old stock rad hoses, a length of heater hose and new clips.
this looked abit dodgy and clear air line type pipe had gone hard.
starting to come together with a quick flash with a black rattler can. me dad painted grille white think it looks better than black.
walt1984
Postby walt1984 » Tue Sep 04, 2012 10:26 pm
back together.
a test run out in rain :(
nothing leaks but something on wiper rack rattles.
did a little tiding in back the water pump took most of the shelf up and was leaking but i forgot to take a before picture.
wirings a bit same way.
walt1984
Postby walt1984 » Tue Sep 04, 2012 10:54 pm
camped at masham steam rally in north yorkshire back in july. our blue mk 7s parked next door.
took some pictures of other transit there.
[IImageMG]http://i1060.photobucket.com/albums/t451/walt1984/418e7ab8.jpg[/IMG]
all been converted to 2.5 di with 5 speed box.
walt1984
Postby walt1984 » Wed Sep 05, 2012 10:39 pm
done a few little jobs this weekend 2nd sept12.
had chance to put van over a pit to change middle section of exhaust but found some rust some1 had covered up! :(
drivers side is worse maybe because mud flap is missing.
good news is that all the major load bearing areas are solid.
had time to change long over due oil and filter
fill it back up with some quality 20/50 oil and some wynns additive. is 20/50 correct grade for a v4?
also found this when looking for photos on mobile, a radio station i picked up somewhere near peterbough i think.
walt1984
Re: 1977 mk 1 camper
Postby walt1984 » Wed Feb 13, 2013 9:09 pm
just typed up a update then lost it all somewhere. where the hell does it go ?
had chance to go and do a few things to camper but im limited to what i can do coz shed has no power or heat brrr.
things done.
stopped drivers side manifold blowing.
re-bushed clutch pedal. i think brake pedal has been done because pivot pipe will come out without taking clip off.
got hazards working. a loose wire in plug and a blown fuse.
got screen washers working. blown fuse and wire shorting out on bulk head.
fitted a ipod/cd radio.
pushed wiring grommets back into place.
made a start on rotten head light bowl.
new pedal bushes.
think this was supposed to go in focus but its been hanging round since we sold fiesta 2 years ago.
i've left standard radio in place and run ipod lead out of ashtray to keep the original look im wanting. new radio works off key on I but thinking about it i should have put a switch on to run off engine battery or leasure battery.
had some old surround sound speakers left so used two for time being untill i can think how to hide em.
while glove box and heater panel was out to run wires about i connected middle screen vent pipes back on to heater box and emptied side window vent pipe of leaves and crap. found washer pump fuse next to wiper motor.
drivers side headlight bowl is rotten but i thought passenger was good but after poking a screw driver about its as bad.
i think it was filler, seem sealer, tin foil ! and mud.
at some time its been waxoiled but never kept up to so most of it is good but tin worm has set in other places.
its off for welding work next week end, got some ramp time sorted at local mechnics.
walt1984
Postby jonochap » Wed Feb 13, 2013 10:31 pm
Coming on lovely that is!
jonochap
Postby Frank190 » Thu Feb 14, 2013 8:07 pm
Lovely MK1 - V 8)
Frank190
Postby walt1984 » Mon Feb 18, 2013 9:19 pm
we had a break in at weekend. builder opposite to ours had his van parked in shed broken into. he rang me to say ours had been broke into. locks cut off sheds worst thoughts of camper gone or vandalism got there and its not been touched big relief. they had dragged out a fireball heater, strimmer and boxed up some tools( spanners, molegrips, socket set etc.) but left em outside must have been disturb. on a lighter note getting some welding done on Saturday hopefully learn to do abit. :)
walt1984
