network rail
network rail
Postby explorer » Mon May 06, 2013 11:50 am
Hi could any one with the x network rail vans tell me i want to remove the light sensor at the top left of the side door as you enter for a normal 240 light switch switch could you tell me wiring does the earth go in the common ?
explorer
Re: network rail
Postby ake » Wed May 08, 2013 4:36 pm
explorer wrote:Hi could any one with the x network rail vans tell me i want to remove the light sensor at the top left of the side door as you enter for a normal 240 light switch switch could you tell me wiring does the earth go in the common ?
How many wires do you have?
A switched live
A permanent live
An Earth
If you have the above, connect The permanent live to Common, and the switched live to L1
Put the earth into a piece of connector strip on its own, or tape it up, you dont need it.
Re: network rail
Postby explorer » Thu May 09, 2013 10:23 pm
AKE CHEERS FOR THAT
explorer
Re: network rail
Postby ake » Sun May 12, 2013 12:31 pm
:D
