Would want to power:
240v AC - phone charger, laptop, lamp
12v DC - LED lights, fridge maybe
Plan is to buy a leisure battery and an intelligent split charge relay (I don't want to wire into alternator or ignition wires).
I already have a 70W inverter.
Not being electrically minded, my main worry is frying myself. Secondary worry is flattening the main battery. Does my setup look safe and workable? In particular, does the black wire from leisure battery negative to crank battery negative safely earth everything (or do I have to run leisure battery negative to the chassis itself?)?
Please also make suggestions about wire thickness, fuse strength and location etc.
