Just wire brushed the floor of my transit and was wandering what the best thing to use protect it is?
Sent from my SM-G900F using Tapatalk
Beaker wrote:Waxoyl does not set, it stays runny. That could cause problems if it gets hot and soaks up into your floor boards. I'd use Dinitrol.
boltondigger wrote:Beaker wrote:Waxoyl does not set, it stays runny. That could cause problems if it gets hot and soaks up into your floor boards. I'd use Dinitrol.
Dont you insulate the floor? waxoil cant penetrate that?
