The previous owner screwed the floor panel into the floor, in some places you can see through to the road - through the screw holes. Dinitrol seems to be the favoured option for rust prevention. I am thinking the best solution would be to treat the holes with a rust preventer (dinitrol) then put screws through the holes again, to seal the hole. and repaint with Dinitrol. How does this sound? Are there better solutions? Can you also buy dinitrol in Halfords/on the high street or am I best to order on line and if so which one, when I looked last time there seemed to be multiple options? ...... and finally, how do you suggest fitting the replacement floor. I will be installing insulation, then a wooden sheet then carpet, how do I fit the wooden sheet, just do some really good carpentry?
Cheers
