Advice on adding a 12v system to my current 240v system ?
Postby tmm » Sun May 14, 2017 3:40 pm
HI
I currently only have a 240v electric system in my van conversion( big mistake i have made with the conversion :( ) I like to add a 12v system linked into the 240v setup how difficult would this be without wrecking my van and what else would i need to do it please? Or would it be easier buying a little generator?
cheers
tmm
Re: Advice on adding a 12v system to my current 240v system
Postby robbie.cee » Sun May 14, 2017 3:44 pm
Car battery charger plugged into 240v to give 12v??
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby tmm » Sun May 14, 2017 3:46 pm
robbie.cee wrote:Car battery charger plugged into 240v to give 12v??
Hi mate.
Ideally im looking to add the 12v system just in case there is no electric hook ups at hand
tmm
Postby robbie.cee » Sun May 14, 2017 3:48 pm
Yeah so really everything should have been 12v to start with and then a 240v to 12vdc transformer used to charge leisure batteries when mains available.
Basically you be best to add additional 12v lighting etc on seperate circuits and power em from battery which in turn gets mains charger or such to top up batteries when mains available
Had
MAKE IT FIT
robbie.cee
Postby tmm » Sun May 14, 2017 4:40 pm
robbie.cee wrote:Yeah so really everything should have been 12v to start with and then a 240v to 12vdc transformer used to charge leisure batteries when mains available.
Basically you be best to add additional 12v lighting etc on separate circuits and power em from battery which in turn gets mains charger or such to top up batteries when mains available
Yea that is what i should have done mate. I Will have a in depth look at what you say if its gonna be a pain in the arse i will just get a generator.
tmm
Postby robbie.cee » Sun May 14, 2017 4:57 pm
Easy to add 12v lights and switches in a vehicle!
Had
MAKE IT FIT
robbie.cee
Postby tmm » Sun May 14, 2017 5:13 pm
robbie.cee wrote:Easy to add 12v lights and switches in a vehicle!
What about invertors? they any good?
tmm
Postby robbie.cee » Sun May 14, 2017 6:00 pm
Yeah but waste of energy if can just use a 12v flouro or led strip like in caravans
Had
MAKE IT FIT
robbie.cee
Postby tmm » Sun May 14, 2017 11:51 pm
robbie.cee wrote:Yeah but waste of energy if can just use a 12v flouro or led strip like in caravans
Ah i see. Cheers for all the advice bud
tmm
Postby andz327 » Mon May 15, 2017 3:59 pm
Mind some places/sites won't let you use generator after certain time due to noise
Sent from my D6603 using Tapatalk
andz327
Postby ceurieusneus » Mon May 15, 2017 5:35 pm
People who runs generators are not the most loved ones on camper places :mrgreen:
Why don't you start telling us for what purpose you want the 12volt?
Is it just for a light? ... do you need more power? TV, satelite dish, computer radio?
How much AH would you use daily?
I always would recommend the use of a leisure battery. 8)
I would also recommend to have all connections made, calculations done, fuses installed, by someone who knows what he is doing. :wink:
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby robbie.cee » Wed May 17, 2017 2:39 pm
11pm usually
Had
MAKE IT FIT
robbie.cee
Postby tmm » Mon May 29, 2017 2:32 pm
ceurieusneus wrote:People who runs generators are not the most loved ones on camper places :mrgreen:
HI Cheers for the reply.
It mainly to add another option which i really should have done before i put it all together :oops: . ITs a mainly for another option. It will run a small tv, charge phone and a 4 meters of these DC12V Waterproof Flexible LED lights
Would a battery and a split charger be ok to run these?
tmm
Postby Beaker » Mon May 29, 2017 4:40 pm
If your TV is low input wattage, and you only use it for a couple of hours, then that should be fine.
If in doubt just calculate your maximum amp/hour figure and see how long your battery is likely to last.
2011 SWB medium roof 2.2l Mk7 115 T300 in Frozen White. Stealth Camper converted.
"It's better to burn out, 'cause rust never sleeps..."
Beaker
Postby tmm » Thu Jun 22, 2017 1:22 am
I have just started converting my second van, So this time Robbie.cc i'm going to add a split charger, 12v sockets, 12v led lights and a 12v water pump, the only 240v i will have will be via a hook up point which will then be linked to a transformer to charge the battery. Does that seems about right? Do you know which transformer is the best for doing the charging of the battery?
tmm
