Single front to double
Postby SteveClay » Mon Jun 05, 2017 8:48 pm
Hi, I have a mk7 based coach built motorhome and I want to put a recently purchased double seat in the front for when we cart grandkids about.
I understand the holes all line up but the double seat base has a 5th hole at the rear, what size bolt is required for this and also what size bolt is required for the double seat belt stalk?
Thanks steve
SteveClay
Re: Single front to double
Postby straydog » Tue Jun 06, 2017 7:47 am
Hi,
I've just done the opposite, ie taken the double seat out to replace with a single swivel seat.
I can tell you the rear seat bolt is slightly larger than the others, so poss 12mm, but the problem is I think it's a weird thread.
It's certainly not the normal 12mm thread, it could be 12mm fine (don't take my word for it)
My seat belt stalk bolt was the same as the seat mounting bolts.
HTH Dog
straydog
Postby SteveClay » Fri Jun 09, 2017 7:28 am
Hi yes helps a lot. Is the rear bolt a ribe profile?
SteveClay
Postby jonochap » Fri Jun 09, 2017 1:01 pm
There was no captive nut in puk so we used bolts, nuts and plates
Owner of not so troubled puk :)
jonochap
Postby straydog » Fri Jun 09, 2017 5:52 pm
SteveClay wrote:Hi yes helps a lot. Is the rear bolt a ribe profile?
Yes, T55 I think
straydog
