Gas cylinder contents
Postby GBW » Thu Jun 15, 2017 12:34 pm
What is the best way of measuring (preferably without removing the cylinder from its locker)?
GBW
Re: Gas cylinder contents
Postby bigjohnthomas » Thu Jun 15, 2017 7:11 pm
pressure gauge before the regulator :?:
bigjohnthomas
Postby bulls in transit » Thu Jun 15, 2017 7:52 pm
Don't they do a sort of cradle that bottle sits on with a weight gauge on,so that say your 10 kg bottles 9kg lighter than when you put it in you'll need another soon(if your still using it!)
bulls in transit
Postby bulls in transit » Thu Jun 15, 2017 7:57 pm
bulls in transit
Postby CamperVanBeethoven » Thu Jun 15, 2017 8:50 pm
There is this trick, although it involves either taking the cylinder out, or getting your gas locker wet ...
http://lifehacker.com/5926183/estimate- ... s-of-water
CamperVanBeethoven
Postby GBW » Fri Jun 16, 2017 9:32 am
bigjohnthomas wrote:pressure gauge before the regulator :?:
That is what I always assumed and many regulators have such a gauge. It is useful as it shows you when the bottle is empty but that is its only use and you know that anyway as the cooker won't light!
As the liquid gas boils off, it is always at approximately a constant pressure.
GBW
Postby GBW » Fri Jun 16, 2017 9:36 am
bulls in transit wrote:Don't they do a sort of cradle that bottle sits on with a weight gauge on,so that say your 10 kg bottles 9kg lighter than when you put it in you'll need another soon(if your still using it!)
That is the way I am thinking although it would be nice not have to open the locker and maybe remove the bottle to find the result.
I wonder if there is such a thing as a strain gauge linked to a remote indicator (I love gadgets!).
GBW
Postby dumper » Tue Jun 27, 2017 8:31 am
I only use gas for cooking so the 3.5 kg bottle lasts a long time when I go to Ireland fishing and not sure about getting calor gas over there and not wanting to swop the bottle till it's empty I take a single burner camping stove it takes up little room and a gas can lasts long enough to tide me over till I can get a new bottle
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
