Hopefully these pictures will come out ok. These are the photos are the same ones I sent to dvla to get my van registered as a motor caravan. It is not finished by a long way (only problem is wife wants more room)
jonnyboy1958 wrote:Thank you Campervan Handyman. I am having withdrawal symptoms though........Cannot wait to start my next project!
jonnyboy1958 wrote:Have to show one at a time
jonnyboy1958 wrote:Hi, I fitted them myself. At first I was a bit worried at cutting a hole in the side of my van, but once you start you have to carry on! They were easier than I worried about!
If you look at this window you can see the shape of the body edged in black? This is the inner body skin edge and a lot small than the size of the glass . You are cutting out to this edge then you install the glass from the outside to the body shape (oblong) it leaves a wide margin 2/3 inches in places which you apply the glue/pu/mastic, then tape into place. Hope I have explained it properly sorry if I haven't.Campervan Handyman wrote:jonnyboy1958 wrote:Have to show one at a time
Were the side windows already in the van or did you fit/have them fitted ?
