Anyone fitted a awning to mk 8
Postby dumper » Thu Jan 04, 2018 7:47 pm
Trying to get a awning for my mk8 L4H3 local camper builder has been on to manufactures and they are saying cannot be done as it will foul the sliding door as anyone fitted one and what did you use thanks
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Anyone fitted a awning to mk 8
Postby greedy007 » Fri Jan 05, 2018 6:38 pm
Are you looking for a wind out or a drive away?
The only way your going to do it is with a fiamma style and bolt through the roofline or if u want a driveaway get a high roof with an overslung fixing
Hope this helps
I just sell then i dont know how to fix your intermittent issue
greedy007
Postby dumper » Fri Jan 05, 2018 8:57 pm
Thanks yes it’s the wind out I am after but the camper conversion company have been on to Fiamma and another make and they say no it will hit the door but to me it looks as though it will bolt through the side of the van above the door I’d like to get a photo of one fitted an know what was used to fit it
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Tipperolly » Sat Jan 06, 2018 8:59 pm
I to am having this problem, I reckon the Fiamma f65 roof mount with some custom brackets will be fine, my mk 8 is a l2 h2 so only about 2-3” above side door so can’t have a f45 wall mount...
Tipperolly
Postby dumper » Sun Jan 07, 2018 10:41 am
Mines L4H3 and has about six inches above the door and tapers in not really a lot and looks like it should be a easy job to bolt thro the side of the van like you see them on caravans and chassis bolt campers I can’t believe Fiamma are saying they looked at this and it is not possible the main reason I am updating to a mk8 was been a twin wheel bus I am not going to overload it and to be able to fit a awning.
I did not want to strip out my my mk6 to fit an awning as it would be a lot of work on a 11 year van even body an mechanically it’s spot on and would last a few more years so at the moment I am a bit gutted I shall have to start the conversation and build it so I have easy access to the side and fit one afterwards instead of starting with th awning
Cheers mate
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Tipperolly » Tue Jan 16, 2018 5:49 pm
Success! Finally fitted the f45s today, I had to get some fiat roof mount brackets modified but now it just bolts straight into the roof rack mounts
Tipperolly
Postby dumper » Tue Jan 16, 2018 8:10 pm
Hopefully me to van going John cooper motorhomes in Scunthorpe tomorrow to be fitted :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Tipperolly » Tue Jan 16, 2018 8:51 pm
Tipperolly
Postby dumper » Wed Jan 17, 2018 1:09 am
Looking good mate also your inside fit out in outher post :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Tipperolly » Wed Jan 17, 2018 8:43 am
This is the modified bracket
Tipperolly
Postby hectors-tranny » Wed Jan 17, 2018 10:38 am
Two heavy duty suction cups, small tarp, set of telescopic poles and lines - total = £40 on Ebay.
Takes two minutes to set up, no drilling through your bodywork, packs away to nothing, and can be fitted to either side :-)
hectors-tranny
Postby bluebottle » Fri Jan 26, 2018 5:21 pm
hectors-tranny wrote:Two heavy duty suction cups, small tarp, set of telescopic poles and lines - total = £40 on Ebay.
Well, jiminy. I have some of the heavy duty glass moving suction thingers for taking imacs apart. I never through of this alternate use for them. I tip my hat to you sir. If I had a tippable hat. I would tip it.
I can't even find my woolly hat so, well.
suction cups!! amazing.
bluebottle
Postby hectors-tranny » Fri Jan 26, 2018 6:28 pm
Ha ha - thanks!
I bought these guys... http://gocaravan.co.uk/accessories/1761 ... tener.html
hectors-tranny
Postby bluebottle » Fri Jan 26, 2018 8:41 pm
Ha ha - thanks!
Those are pretty smart, I like the metal attachment point. Mine are less fancy looking but significantly cheaper.. (smaller as well)
https://www.amazon.co.uk/dp/B0036W70BG/ ... 11_TE_item
bluebottle
Postby dumper » Fri Jan 26, 2018 10:36 pm
All sorted now John Coopers have done a great job highly recommend
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
