bluebottle wrote: starter batteries and leisure batteries are designed for fundamentally different output
To add a bit, a starting battery is optimised to deliver insane amount of current for a second or two, totalling a small fraction of 1 Ahr of discharge. Soon as engine starts the starting battery is hammer-charged with up to 90 Amps to put that <1Ahr back again as rapidly as possible. The way the factory 'pastes' a starting battery's plates is more to compete in a 'cold cranking amps war' than for survivability, which means the plates 'shed' like crazy when using any more than single-digit Ahrs of discharge. That's why the "A-hrs rating" is dissappearing from specs and replaced with [one-time-only] "reserve capacity".
So a leisure battery being the complete opposite to that, in order to survive needs the appropriate kind of charging while in motion. I've heard of people in past getting away with just using a series-ballast headlight bulb with a simple relay,but today two decades into the 21st century there must better!
