motorcaravan speed limits?
Postby solarman » Wed Jan 19, 2011 7:31 pm
I have read in several forums that a van converted to a motorcaravan is allowed to go 'faster'regarding speed limits?Surely speed limits apply to all vehicles don't they or are there special cirmstances/ specific carriageways ,roads where this will apply?Can some one clarify this if possible with some examples,thbanks,
Solarman.
solarman
Re: motorcaravan speed limits?
Postby SteveDSD » Wed Jan 19, 2011 7:49 pm
On a single carriageway the speed limit for a panel van is 50, a motorcaravan can do 60 the same as a car. On a motorway a van can do 60 and a motorcaravan can do 70. Obviously 30 and 40MPH and any other posted speed limits apply.
Grab a copy of the highway code, a lot of things change over time and it can be worth while keeping up to date.
2000 SWB 100-Campervan/Dayvan/Moneypit
Image See the van at http://www.fordtransit.org/forum/viewto ... 58&t=44950 Image
SteveDSD
Postby Luke » Wed Jan 19, 2011 8:19 pm
SteveDSD wrote:On a single carriageway the speed limit for a panel van is 50, a motorcaravan can do 60 the same as a car. On a motorway a van can do 60 and a motorcaravan can do 70. Obviously 30 and 40MPH and any other posted speed limits apply.
you mean dual carrage way on a motorway both van and cars can do 70 :D
Postby solarman » Wed Jan 19, 2011 8:30 pm
so if there is 50 mph limit on a dual carriageway and i had a van then it's 50 mph,but if i had it changed to a motorcaravan
i could then go at 60 mph?Why is this,not disputing you but just curious?
solarman
Postby SteveDSD » Wed Jan 19, 2011 8:31 pm
Just checked and -
Only car-derived vans with a maximum weight of under 2 tonnes are subject to the same speed limits as cars. In other words, all Transit-sized vans (and some smaller ones) are subject to a different set of speed limits to cars.
Here are the correct speed limits for most vans:
Single carriageways: 50mph
Dual Carriageways: 60mph
Motorways: 70mph
SteveDSD
Postby SteveDSD » Wed Jan 19, 2011 8:32 pm
solarman wrote:so if there is 50 mph limit on a dual carriageway and i had a van then it's 50 mph,but if i had it changed to a motorcaravan
If there is a posted limit of 50 on a dual carriageway then everyone has to stick to the 50 posted limit.
See http://www.dft.gov.uk/pgr/roadsafety/sp ... peedlimits for details
SteveDSD
Postby Luke » Wed Jan 19, 2011 9:03 pm
the variable limits are only when you see the national speed limit applies sign :D
Postby Stuart121972 » Fri Jan 21, 2011 1:43 pm
Luke wrote:the variable limits are only when you see the national speed limit applies sign :D
OK, so just to throw a spanner in the works, when you enter a motorway in Soctland they have this sign
It's misleading as it does not mean you can do 70 in a HGV.
Stuart121972
Postby fedup2 » Fri Jan 21, 2011 5:47 pm
No but drivers of restricted vehicles should know the limits for the vehicle they are using.
The limit for hgv's over 7.5 ton is 60mph.On a motorway there is no difference for 7.5 ton and under.
Launch x431 owner ;)
fedup2
Postby mike.T » Sat Jan 22, 2011 7:43 pm
See enclosed Link regarding the UK speed limits
http://www.smartdriving.co.uk/Driving/D ... imits.html
Regarding campervans If you are over 3500 Kg in europe the law is a bit Gray
I spent a lot of time looking up this subject as I was 3850-kg with a car on a trailer behind
no problem up to 3500-kg
The law and speed limits changed in 2000 when they brought in new road tax laws regarding
Camper-van's or Motor-caravans, Private Goods class was introduced for camper-vans over 3500-kg and slightly lower road tax I pay £195 on my van
Mike
mike.T
