Wood Burners...
Wood Burners...
Postby markyc » Fri Sep 16, 2011 4:52 pm
I'm about to start re-doing an ambulance camper conversion and would like to fit a small wood burning stove. Anyone fitted one in their van? Got any hints or tips? Thanks :)
markyc
Re: Wood Burners...
Postby hilliebilly » Fri Sep 16, 2011 7:36 pm
leave the wood burner out caravan sites dont allow them and when it comes to sellling people dont seem to like them but its up to you
hilliebilly
Re: Wood Burners...
Postby Northwest2go » Fri Sep 16, 2011 7:59 pm
Yes waste of time as you won't be accepted unless your going to get a dog on a bit of string , park in lay by's and hug trees.
06 MK6 camper conversion, Mercedes C180,
98 Alfa spider ph2 2.0 TS, 2000 alfa spider & 99 alfa GTV V6 3.0.
Northwest2go
Re: Wood Burners...
Postby bigjohnthomas » Fri Sep 16, 2011 9:54 pm
Northwest2go wrote:Yes waste of time as you won't be accepted unless your going to get a dog on a bit of string , park in lay by's and hug trees.
:lol: :lol: :lol: :lol:
bigjohnthomas
Re: Wood Burners...
Postby priesty » Fri Sep 16, 2011 10:08 pm
seen one in a mk5 on the tv a few year back it had tiles right up behind it with a slab for a hearth think it woz just behind the drivers seat
priesty
Re: Wood Burners...
Postby redcube » Fri Sep 16, 2011 11:00 pm
I seen one in a mk2 ambulance at the scrap yard why it was there you may ask well it was one hot ambulance it caught fire
redcube
Re: Wood Burners...
Postby johny transit » Sat Sep 17, 2011 11:08 am
I would have thought even a small stove is gonna generate too much heat. I've got a stove in my living room, you can't sit in front if you stoke it too much! They are very powerfull. Would need serious heat shielding all round it.
Sorry to be so negative :(
"There's always a way"
johny transit
johny transit
Re: Wood Burners...
Postby sc_BK » Fri Sep 23, 2011 11:24 pm
For the amount of space it'll take up because of the clearence you'd need, it's not really worthwhile, even though it would be a very cheap way of heating your van
You'd be aswell to fit a diesel night heater, you could even fit a 2nd tank and run it off red diesel
OR
buy a wooly hat :wink:
sc_BK
Re: Wood Burners...
Postby sc_BK » Fri Sep 23, 2011 11:38 pm
I'm only ever wildcamping, I have a woodburning stove which I use outside the van for sitting around and cooking on. You can stick the kettle on and fill a hot water bottle :wink: :)
sc_BK
Re: Wood Burners...
Postby markyc » Sun Sep 25, 2011 4:35 pm
Thanks for the comments guys, I still like the idea of a wood burner but probably its not really practical! I didn't think I could fit a diesel heater because its a petrol ambulance but I hadn't thought of a second tank. Theres loads of room underneath and i'm guessing it wouldn't need to be very big.
markyc
Re: Wood Burners...
Postby SteveDSD » Wed Sep 28, 2011 7:54 pm
If you have LPG for your cooker/fridge or whatever then you might want to think about a Propex heater rather than the diesel one, as they're cheaper and seem to be more reliable.
2000 SWB 100-Campervan/Dayvan/Moneypit
Image See the van at http://www.fordtransit.org/forum/viewto ... 58&t=44950 Image
SteveDSD
Re: Wood Burners...
Postby chris2790 » Thu Sep 29, 2011 11:04 pm
Go for it mate 8)
i'd love to put one in my county - but it wasn't necessary for west africa!
most trucks i've seen with them in, use a tiled floor or chequer plate. Check out the onlineshop on www.firecement.co.uk for insulating panels though, they do some nice thin board and various other heatproof equipment.
witches hats generally seem best for the top, but beware of where you put it (re: catching on branches)
bear in mind that the more flu in the van, the bigger the heating area.
also consider the condensation issues you may have, along with the need to supply fresh air also.
Are you making your own burner or buying one? i've seen a real good south african pot belly type stove, at an overland exhibition but i can't remember what it was called. :roll:
or build you van then piss off somewhere warm every winter!
(ps - ignore the scuzzy hippy comments, and let them be cold... but still upstanding members of society :wink: )
chris2790
Re: Wood Burners...
Postby vana mana » Wed Oct 26, 2011 5:49 pm
Check out ..boatman,windy smithy,or snail stoves..got some cute burners..
vana mana
Re: Wood Burners...
Postby ursus » Thu Oct 27, 2011 9:07 am
I used to have a woodburner in a couple of caravans I used to own.They took up a bit of space and could get very warm,but when it's minus 10 outside,I was sure nice and toasty :D :D also machine mart woodburners are rated value for money amongst a few hippy travellers I know.
ursus
Re: Wood Burners...
Postby vana mana » Sat Oct 29, 2011 2:44 pm
ursus wrote:I used to have a woodburner in a couple of caravans I used to own.They took up a bit of space and could get very warm,but when it's minus 10 outside,I was sure nice and toasty :D :D also machine mart woodburners are rated value for money amongst a few hippy travellers I know.
Get orf my land..lol..u go on Tribal Living ?
vana mana
