by growntree » Sun Sep 10, 2017 5:39 pm
Should just be a case of hooking them up to the existing wiring. I've not checked out the light in the back of mine, but if you've got two wires going to it, then just use them, although you'll have to get them the right way round as LEDs will only work one way round. If the original light has a switch, then there might be three wires, one of which will just be permanently connected to ground.
Hope that helps.
G
