Hi everyone,
Looks like I'm another Aussie Transit owner signed up to your forums.
I have recently bought a 2005 build 135 T350 Transit.
Trying to identify some issues lead me to this forum, so I hope the answers will be here!
I've been trying to determine why the Hazard Switch doesn't activate hazard lights.
Have tried both the switch and flasher unit in an earlier build (2002?) Transit and both these work ok.
I have checked the wiring at the switch and relay, and reading up in a Haynes manual has revealed my wiring is different.
My van has the deadlocking function on the remote, when deadlocked it does flash all indicators at once.
I'm going to assume at this point that my van has a body control module or similar, and the hazard switch goes into that.
Failing that, somewhere someone has done some custom wiring, and this is causing a problem.
I cannot locate a wiring schematic for my van to identify where the hazard switch is wired to, and the wiring colours.
I've spent a bit of time searching these forums, but as yet not found the answer I'm after...
Any help would be appreciated.
Regards,
Dion
