i have a 2005 transit t350 90 rwd tipper , it recently bent a valve, decided to put in a replacement engine, and have done so it was from a 2000.
I put in the new engine along with its ecu and diesel pump and key reader, the van runs sweet as a nut, but I have no speedo, rev counter, temp gauge and odo reads dashes.
after doing some digging on here I have read that I would need to get the ecu reprogrammed? is this the case?
or if I was to put the original ecu pump and key reader back in would this solve my problem? or is the engine coded too?
any help/advice would be greatly appeciated
thanks
Keiran
