help
New member? Post here to say Hi, tell us about yourself and your Transit!
Moderators: Luke, AlanN
help
Postby keirand89 » Sun May 13, 2018 10:10 pm
i have a 2005 transit t350 90 rwd tipper , it recently bent a valve, decided to put in a replacement engine, and have done so it was from a 2000.
I put in the new engine along with its ecu and diesel pump and key reader, the van runs sweet as a nut, but I have no speedo, rev counter, temp gauge and odo reads dashes.
after doing some digging on here I have read that I would need to get the ecu reprogrammed? is this the case?
or if I was to put the original ecu pump and key reader back in would this solve my problem? or is the engine coded too?
any help/advice would be greatly appeciated
thanks
Keiran
keirand89
Re: help
Postby andz327 » Tue May 15, 2018 12:15 pm
keirand89 wrote:i have a 2005 transit t350 90 rwd tipper , it recently bent a valve, decided to put in a replacement engine, and have done so it was from a 2000.
thanks
Keiran
Would imagine dash clocks are different on a 2000 compared to 2005, why didn't you just put your pump on new engine ?
andz327
Re: help
Postby Luke » Tue May 15, 2018 10:38 pm
hello and welcome to the forum :D
Return to Welcome
