1984 Mk2 Transit Crew Bus
New member? Post here to say Hi, tell us about yourself and your Transit!
Moderators: Luke, AlanN
Postby Denzil » Wed Mar 25, 2009 12:48 pm
Hi. I've got a 1984 Mk2 short wheel base Transit 2litre (affectionately known as Jorge) which began life as a crew bus and was run by a UK University Department for field trips. It's done just over a 100k miles since new on the original engine, the only modification being a Weber carb. This sturdy beast has done ten trips to southern Spain and back and is the best all-round vehicle I have ever owned. 4WD drivers have no idea how versatile this vehicle can be in off-road situations! I've just had some welding carried out on the chassis and may be in need of a steering box sooner or later, plus other bits and pieces as I intend to keep Jorge on the road. Any help I can get on accessing spares, technical advice etc will be most welcome.
It's good to know you're out there.
Denzil
Re: 1984 Mk2 Transit Crew Bus
Postby Luke » Wed Mar 25, 2009 1:02 pm
welcome mate :D
cant you adjust the box :?:
Postby BigNeil » Wed Mar 25, 2009 1:36 pm
Welcome to the forum :D
BigNeil
Postby ake » Wed Mar 25, 2009 8:00 pm
Welcome :)
Postby transitandy » Wed Mar 25, 2009 8:34 pm
welcome :D
Postby AndyG » Wed Mar 25, 2009 8:49 pm
Welcome :D
Postby Britishbulldog » Thu Mar 26, 2009 6:06 pm
welcome :)
Britishbulldog
formerly known as charly
Postby Denzil » Thu Mar 26, 2009 8:16 pm
Thanks for welcome! :D
I think the steering box is adjusted as far as it will go, but without taking it apart and letting someone skilled assess it, I don't know how long it's got to go. It's never failed an MOT, but the play on the steering wheel seems to be increasing and I was told some time back that 'it's gonna need replacing at some point'...
I've got a leaking windscreen and suspect the metal rim is rotten underneath. Mastic's doing a holding job for now. Any thoughts on fixing the problem?
Denzil
Postby Ford Sprung Van Tastik!! » Thu Mar 26, 2009 9:03 pm
Welcome :D
Rare genuine Mk5 190 LWB 115ps Turbo Diesel Intercooled .
If you can't fix it... use a BIGGER hammer !!!
Postby bigal9440 » Wed Aug 16, 2017 9:50 pm
Hi Denzil, I noticed on another thread that you were thinking of selling Jorge. Is he still available? Contact me if so. Thanks.
bigal9440
Return to Welcome
