dumper wrote:When I built my camper out of a mk8 bus there was holes in the plastic side panels to take a power sockets but I cannot remember seeing any wires but if they had they’d probably turn off 30 mins after engine turned off .maybe you can wire your own in form the consumer point on side of drivers seat or run one of those cigarette 3 socket extension leads into the back or get a smaller work mate
dumper wrote:How about running it off a jump pack then use in the day charge at night
siraff wrote:My minibus has a 12v in the rear panel next to one of the seats. Not sure if the loom is always there but its in the rear right panel if you want to have a look.
Even if not I would imagine there will be power for something down there (interior lights, towbar or similar) so as long as its not a massive drain you should be able to pick it up from somewhere.
dumper wrote: they’d probably turn off 30 mins after engine turned off
