CMBDAVE wrote:Hi
My 2015 MK8 155ps chassis cab has been going into limp mode, my Ford dealer has diagnosed and fitted a new fuel temperature sensor .
All was fine but now it has started again with limp mode,infact it has done it three times since the new sensor was fitted.The dealer has done a fault check but no new fault code is showing up just the origonal fuel temperature sensor fault code.
It goes into limp mode but then sorts itself out once the engine has been turned off and back on again.
The dealer says that without a new fault code there is nothing that they can do and after a week at the dealer where they drove the vehicle with no problem accuring i was advised to take the vehicle back, use it as normal and if the fault happens again to take it back to them for another look to see if there is a new fault code showing.
The vehicle has done 75000 miles with no problem up until now and i was wondering if anyone else has had a limp mode problem and if so how was it put right.
Marky s wrote:Hi I've been told mines the maf sensor but seams strange as van runs fine once restarted any one heard of this and would it be fixed under warranty
