Hi guys,
I have an original dual battery system and my own third board battery added.
Holding charging convertor in my hands which will be used for charging the third battery while motor runs.
BEMM says "do not connect anything to the starter battery".
Do you know why there is such restriction ?
Is it because Ford likes only have starter battery isolated from all consumers, or because of real problem with control unit etc. ?
(Starter batterey would keep more power for invertor I would say ).
I´m decided to follow Ford instruction and plan connect convertor to customer connection point (Ford auxiliary battere respectively), but I´m courius about .....
Thanks in andvance.
rasu
