Mike wrote:RWG Contracts wrote: it starts reminding you from 1800 miles.
This is what I'd be using to make my case. Warning you 200 miles after you've filled the adblue tank shows that there's a problem.
Yes my thoughts as well
Damien89 wrote:How much adblue do you use to fill the tank every time you fill the adblue tank?
RWG Contracts wrote:Damien89 wrote:How much adblue do you use to fill the tank every time you fill the adblue tank?
Nearly 40 litres
Nearly 40 litres
mavericktc wrote:RWG Contracts wrote:Damien89 wrote:How much adblue do you use to fill the tank every time you fill the adblue tank?
Nearly 40 litres
Interesting.
According to the brochure it only holds 22 liters.
Damien89 wrote:RWG Contracts wrote:Damien89 wrote:How much adblue do you use to fill the tank every time you fill the adblue tank?
Nearly 40 litres
40 litres?! Are you sure? Mine only holds 21 litres! Your not putting adblue in the diesel tank, are you?
