Rear springs
Rear springs
Postby Blueseaofibrox » Tue Dec 13, 2016 10:14 pm
I've got Mk 8 jumbo transit 64 plate Iam wanting to change the rear spring to heavy duty ones as I carry a lot of weight , does anyone know if this can be done if so is it a big job Cheers John
Blueseaofibrox
Re: Rear springs
Postby Damien89 » Wed Dec 14, 2016 9:48 am
Check the gvw for your van and see if its the biggest gvw, if its not get the springs from the biggest gvw transit. How many leafs has yours got?
Damien89
Re: Rear springs
Postby Blueseaofibrox » Wed Dec 14, 2016 5:41 pm
It only one leaf Spring on it
Blueseaofibrox
Re: Rear springs
Postby Damien89 » Wed Dec 14, 2016 6:27 pm
Blueseaofibrox wrote:It only one leaf Spring on it
If thats the case then you can almost certainly upgrade your springs. My minibus has 3 leafs.
So your JUMBO has just a single leaf? Whats the gross veichle weight?
Damien89
Re: Rear springs
Postby Blueseaofibrox » Wed Dec 14, 2016 7:05 pm
3.5 ton
Blueseaofibrox
Re: Rear springs
Postby V184 » Wed Dec 14, 2016 7:43 pm
i think 3.5 Jumbo only carry 850kg legally
V184
Re: Rear springs
Postby squirrel93 » Wed Dec 14, 2016 9:04 pm
How much weight is "I carry alot of weight"?
squirrel93
Re: Rear springs
Postby Blueseaofibrox » Wed Dec 14, 2016 10:02 pm
How much weight do you put on ??
Blueseaofibrox
Re: Rear springs
Postby brickent » Thu Jan 26, 2017 11:17 am
Bump. Is there any custom springs that you can order? And where's the best place?
brickent
Re: Rear springs
Postby Damien89 » Sun Jan 29, 2017 6:14 pm
brickent wrote:Bump. Is there any custom springs that you can order? And where's the best place?
Mate they are too new for anyone to know who does custom springs specifically for them. Go on ebay and find mk8 rear springs with more than one leaf.
Damien89
Re: Rear springs
Postby niloc1200 » Sat Feb 04, 2017 7:46 am
Jones springs on eBay do a uprated spring for a transit mk8 with a single leaf uprated to a double to carry more weight £348
niloc1200
Re: Rear springs
Postby TaysideTransit » Tue Mar 14, 2017 9:00 am
Hi,
I am thinking of fitting heavy duty leaf springs to mine.
I load evenly and never go over the capacity of the vehicle (2017 MK8 twin wheel jumbo) BUT it always looks down on its backside and there is hardly any clearance between the bottom of the ford fitted tow bar and speed bumps.
Would this affect my warranty? I know this is a question for ford or the dealer but I find them frustrating to talk to. My dealings with them so far have not been positive.
TaysideTransit
