Electrics on the mk8
Postby uggie74 » Sun Jan 01, 2017 5:16 pm
Hi all was just wondering if all the vans are wired the same as I was thinking of retro fitting mine with fog lights and electric mirrors
Sent from my HTC One A9 using Tapatalk
uggie74
Re: Electrics on the mk8
Postby Damien89 » Sun Jan 01, 2017 6:21 pm
You can check behind the front bumper to see if there is the harness for the for lamps, you will also need to change the headlamps switch and get one that has the fog lamps button in it. as for the electric mirrors you will need to pull out the drivers side cup holder and see if there the harness near the headlamp switch and you will need to see if theres the harness going to the mirrors.
Damien89
Postby uggie74 » Sun Jan 01, 2017 6:24 pm
Thanks will try that
uggie74
