Reverse camera feed
Reverse camera feed
Postby Potter1982 » Thu Jan 19, 2017 4:46 pm
Hello does anyone know of another way of getting an reverse feed power supply in the cab of a ford transit mk8 instead of running another wire to the rear reverse lights?
Many thanks
Gary
Potter1982
Re: Reverse camera feed
Postby loot » Thu Jan 19, 2017 5:35 pm
Not off hand but if you go to www.etis.ford.com and put your can details in, you should be able to download bemm, it has lots of useful info and may tell you where to connect at the dash :-)
Ids map here
loot
Postby Fraggle17 » Sun Jul 09, 2017 3:48 pm
Just got my transit custom, i got gifted a reversing camera which is the integrated into the top level brake light, this is fine, the wiring has been put through the van and it appears that this model of camera has both power connectors run through the cab instead of a reverse light power lead then a single cab mounted power lead for the monitor. Does anyone know a way to get these to work from the cab? I have tried powering from 12v socket adapters from halfrauds but they don't seem to be able to power up the screen, it did work when i ghetto tested it on a power pack.
Idea's for wiring much appreciated, don't fancy completely removing the dash because it's my work van not solely a pleasure vehicle.
Cheers.
Fraggle17
Postby Potter1982 » Sun Jul 09, 2017 10:01 pm
Hello Fraggle17 I took a feed from the drivers side 'a' pillar for the reverse feed and got one of those fuse taps for the ignition live to the screen
Gary
Potter1982
Postby Tranny McTranface » Wed Jul 12, 2017 10:42 pm
Hi Potter1982, did you get sorted?
I fitted my reverse park camera and rear view mirror monitor this week and it works a treat so give me a shout if you need a hand.
TMcTF
:D
Tranny McTranface
Postby Potter1982 » Thu Jul 13, 2017 8:45 am
Hello tranny mctranface
Yes mines all sorted thank you works well! What one have you got? Mine a Ring kit
Potter1982
Postby Lordduvet » Fri Jun 05, 2020 10:33 am
Potter1982 wrote:Hello Fraggle17 I took a feed from the drivers side 'a' pillar for the reverse feed and got one of those fuse taps for the ignition live to the screen
Gary
Any chance of helping me out with a pic of which wire and it’s colour?
So far everyone’s saying “ it’s over there”
Lordduvet
Postby Big_yellow_tranny » Sun Oct 18, 2020 1:44 pm
Does anyone actually know the colour of the reverse light wire?
Big_yellow_tranny
