mavericktc wrote:All diesel engines knock when not preheated and it's cold outside.
Damien89 wrote:mavericktc wrote:All diesel engines knock when not preheated and it's cold outside.
But the 2.2 have heaters, no?
mavericktc wrote:Damien89 wrote:mavericktc wrote:All diesel engines knock when not preheated and it's cold outside.
Depending on country and spec, maybe (and that you use it ofc).
There are two types.
Block heater and diesel/aux heater.
In my country the custom and mk7 comes/came with a diesel heater as standard.
Don't think you can buy a block heater from ford as an option.
Damien89 wrote:
I was reffering for the combustion chamber heater.
You mean the glow plugs?
Yes, nearly every diesel have them but that doesn't change the knocking on cold.
A diesel have a high compression and heats up the air until it detonates with the fuel.
A cold engine, that will say when the block/cylinder walls are cold knocking occur.
Google it for a better explanation
dumper wrote:On the old DI,s for cold start the timing was advanced by a unit in the water system and a cable to a lever on the pump as the water heated up it let timeing retard back to the run position when cold some of them had a very bad diesel knock now it's probably advance by the computer that does it .the scania bus at work are very bad when cold ake says it's a diesel thing
Users browsing this forum: yzr750
