If it is the same as the custom it is bad
basically the middle splits like a clam shell, you can remove the circular tab where the mirror would go in the middle, then you basically split apart the 2 halves they join vertically in the centre, you'll most likely brake 1 or 2 tabs tho
still goes back together OK tho.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
07 350 170ps
Ids v86 licence + v86.04 update + xprog
hereIds map
here
