Black piece centre of windscreen
Postby niloc1200 » Thu Feb 09, 2017 9:38 pm
Any one know how to remove this piece as mine vibrates at 2000rpm and drives me mad :?
niloc1200
Re: Black piece centre of windscreen
Postby loot » Thu Feb 09, 2017 10:40 pm
If it is the same as the custom it is bad :-( basically the middle splits like a clam shell, you can remove the circular tab where the mirror would go in the middle, then you basically split apart the 2 halves they join vertically in the centre, you'll most likely brake 1 or 2 tabs tho :-( still goes back together OK tho.
Ids map here
loot
Postby niloc1200 » Fri Feb 10, 2017 6:21 am
I'm surprised I haven't broken it already been pulling on it drove me mad yesterday driving 400 miles I thought first the rattle was under the dash but am glad to work out what it finally was
niloc1200
Postby loot » Fri Feb 10, 2017 10:25 am
Can't you just push something behind it somewhere to stop it? They aren't very good these tbh they clip into each other but i don't think they're actually connected to the screen lol more of an interference fit iirc mine is quiet but i can wiggle it about as it is loose :shock:
Mind you I'm usually listening to the sweet harmony of the machine gun under my bonnet :lol:
Ids map here
loot
Users browsing this forum: Phil Stenning
