2014 new shape transit electrical issues
Postby Hushner1 » Tue Apr 04, 2017 2:42 pm
Hi there we have a 2014 new shape 2.2 rwd transit
We brought it with front end damage
It's all back together but we have electrical issues
Whilst driving the heated front screen randomly get hot and blurry but the switch is turned off after 30 seconds the warning beeper goes off and dash says service engine then after 30 seconds the warning goes off so does the heated windscreen
Also one day engine is quiet the next it's rattley as if the timing is out
Can't find any wiring damaged or find anyone who has had the same problem and ford won't look under warrentl as it's been crash repaired
Any help would be appreciated
Hushner1
Re: 2014 new shape transit electrical issues
Postby loot » Tue Apr 04, 2017 10:06 pm
Have you had it plugged into ids for fault code read?
Also make sure all the little black earth tags on the inner wings are on and tight, they have metal loops tags.
A louse 1 causing a bad connection can make all sorts of gremlins appear.
Ids map here
loot
Postby Hushner1 » Tue Apr 04, 2017 10:41 pm
Hi there thank for the reply
We have checked every earth on the vehicle even double checked them all today in case we had missed any
Will loosen them all off clean put some lube and re tighten them tommorrow
Dignostics keep coming up with dpf pressure issues this after ,3 weeks forces limp mode . We reset values and that part is good for 3 weeks then does it again
Hushner1
Postby loot » Tue Apr 04, 2017 11:00 pm
The dpf sensors and wiring can be faulty i believe.
Ids map here
loot
