Hill Assist
Hill Assist
Postby neepcutter » Wed Aug 09, 2017 11:46 pm
Some electrical faults on my Mk8 Trend Jumbo 155 have all occurred in the last few days don't know if they are all connected
Sliding side door when opened does not illuminate cargo lights but rear ones do,it is also the same for the warning message if you set off with any of the doors open a message appears for the rear ones but nothing for the side
And crucially the hill assist has packed up as well even though it is enabled through the controls
Any Ideas ??
16 plate 350 Jumbo trend SRW 155ps
neepcutter
Re: Hill Assist
Postby loot » Thu Aug 10, 2017 8:16 am
Side door ajar switch isn't working i guess, not sure if it is a plunger or part of the actuator At the moment tho but needs checking.
Any problem with the breaking system may result in hill assist not working.
Maybe get codes read it might show something up.
Ids map here
loot
Re: Hill Assist
Postby 2tall » Sun Aug 13, 2017 7:09 am
Hill assist stops working if one of the doors is open, maybe it's the same when the BCM thingy is not getting any signal from the side door plunger?
2tall
Re: Hill Assist
Postby Damien89 » Sun Aug 13, 2017 8:57 pm
Check the batteries to see if one of them is faulty
Damien89
