Abs light light on and hill assist off
Postby swisstosand » Mon Aug 14, 2017 9:41 pm
Hey guys
I've got a 64 plate l3 h2 trend , just changed front and rear pads
(Motor craft) driven 200mls abs lights come on and also hill assist has been
Deactivated
Also the hand brake is on its limit , about 5 clicks
Any ideas???
swisstosand
Re: Abs light light on and hill assist off
Postby loot » Wed Aug 16, 2017 1:14 pm
Hla won't work if there is a fault in the brakes, I'd suggest undoing the handbrake then work the brakes a bit to adjust up and then adjust the handbrake up to 5 clicks max :-)
You may have damaged an abs sensor hence the fault but ideally you should check for codes.
You can check them at the connector for ohms.
Ids map here
loot
