yes normal most transits have twin battery's one starts the engine and the odd bits and the other powers everything elseAllan007 wrote:Hi all, new to this site and just bought the 350 mk8 transit. Western Power had mine and have put extra electrics in it with a split charger in the back (they removed an additional battery i think)
My question is that my van has two batteries under the drivers seat. is this normal and is one a leisure battery ?
Many thanks for any answers.
Loving the van.
Allan
northhook wrote:Finally got my problem with ”Charging system Service now” solved. Took the car to another Ford service center with a more helpful staff. They found that the ground cable om the starter were loose and didn't have a proper ground connection between the motor and the chassie ground. They did a test and disconnected the cable and the fault message was on the whole time. Then connected it properly and the message was gone. Don't know if that's the solution for others with the same fault message on the display but it's worth checking out.
