How do I remove steering column cover?
Postby Flashback33 » Sun Sep 10, 2017 6:54 pm
In the process of fitting a 'Kill Switch' to the ignition.
Actually I'm fitting a relay, but I need to gain access to the ignition switch wiring.
I've removed the two self-tappers from the lower steering column cover, but the cover won't budge!
Can any one help?
Please!
Flashback33
Re: How do I remove steering column cover?
Postby blindedbythelights » Wed Aug 05, 2020 8:36 am
I'd like to do the same, but probably won't attempt it until I know the method. I have been told you can try this method.
'There is a 7.5 amp fuse that runs starter and all ignition lights run 2 wires from it to a switch and your ignition is dead'
blindedbythelights
Postby Sam123 » Wed Aug 05, 2020 8:56 am
It is just the two self tappers, and then the lower is held to the upper by integral clips at the sides. Once you've removed the tw screws, just gently ease the clips apart, perhaps carefully using a flat head to prise between if needed. It will come eventually.
Sam123
Postby dumper » Fri Aug 07, 2020 4:12 am
Or possibly put a kill switch in the bottom clutch pedal switch wiring.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Sam123 » Fri Aug 07, 2020 11:00 am
dumper wrote:Or possibly put a kill switch in the bottom clutch pedal switch wiring.
That's a good idea - I might do that myself. That seems less risky than messing about the ignition barrel wiring.
Sam123
Postby dumper » Fri Aug 07, 2020 2:44 pm
Hi when you get it done let us know what wire you put the switch in and when you have it started and use the switch does it stop the anti stall from working I’d like it able to turn it off when reversing in tight places cheers Sam ,
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby blindedbythelights » Wed Aug 26, 2020 9:41 pm
following....
blindedbythelights
