mk8 wont start
mk8 wont start
Postby fordv8racing » Fri Oct 20, 2017 1:09 pm
hi all, bought a 2014 mk8 jumbo in august, took it to transitmania 500 mile round trip no problems at all drove like a new van.
two days after returning went on holiday for 3 weeks left van outside workshop, on my return jumped in the van turned ignition all I got was half turn of the engine tired again got the same so thought batterys were down due to bing stood, charged batterys got the same again then when you turn the ignition nothing.
rang mechanic mate he said ill come and test it, tested it and said starter has gone, fitted new starter tried it turned over slow he said charge the batterys and try again, no different.
rang auto electrician he said he would test batteries both came up ok, he said try connecting a lead straight from battery positive and negative to the starter still the same.
mechanic came back and stripped and cleaned all positive and negative connections, still no different don't know what else to try anybody any ideas. if I had any hair I would be pulling it out.
cheers michael
fordv8racing
Re: mk8 wont start
Postby Altransit » Fri Oct 20, 2017 2:41 pm
Disconnect the glow plug relay, or disconnect the wire feeding them, and try again :idea:
Re: mk8 wont start
Postby karl » Fri Oct 20, 2017 8:36 pm
you the silver van or the white van their was only 2 this year
karl
Tranny Lover!!!
Re: mk8 wont start
Postby Altransit » Sat Oct 21, 2017 2:26 pm
This one I believe 8)
Re: mk8 wont start
Postby devonvanfan » Sat Oct 21, 2017 3:50 pm
You say you charged the battery – but was it FULLY charged?
I’ve managed to flatten my battery twice! (Kept opening and closing doors whilst I was fitting it out - and internal lights were staying on for ages).
Only way to solve the problem was to jump start from another van and left it running for a good 10 minutes. Haven’t had problem since although I am now more aware that lights and 12volt sockets stay live for a good 30 minutes once ignition switched off.
devonvanfan
Re: mk8 wont start
Postby fordv8racing » Mon Oct 23, 2017 1:14 pm
karl wrote:you the silver van or the white van their was only 2 this year
the white one
fordv8racing
Re: mk8 wont start
Postby fordv8racing » Mon Oct 23, 2017 1:16 pm
devonvanfan wrote:You say you charged the battery – but was it FULLY charged?
don't think its the batteries as still the same with my snap on charger/booster connected
thanks michael
fordv8racing
Re: mk8 wont start
Postby fordv8racing » Mon Oct 23, 2017 1:17 pm
Altransit wrote:Disconnect the glow plug relay, or disconnect the wire feeding them, and try again :idea:
cant see what difference that will make, but will give it a try.
thanks michael
fordv8racing
Re: mk8 wont start
Postby Altransit » Mon Oct 23, 2017 2:22 pm
thanks michael
The difference is that you're removing the drain of the glow plugs from the starting circuit. If one or more has gone short circuit they can rob power from the starter :)
Re: mk8 wont start
Postby fordv8racing » Tue Oct 24, 2017 11:04 am
thanks michael
disconnected the glow plugs, still the same
thanks michael
fordv8racing
Re: mk8 wont start
Postby Damien89 » Wed Nov 01, 2017 11:59 am
Have you checked the voltage while cranking?
Damien89
