bigjohnthomas wrote:Mines not got got stop start
But if you put the clutch down turn the key the engine starts to turn over .. Let go of the key ... Lift the clutch up a but .. It stops turning over then press the clutch down again and it starts on it own without touching the key
Batshit
Bonkers
White mouse
Mental
Altransit wrote:bigjohnthomas wrote:Mines not got got stop start
Batshit
Bonkers
White mouse
Mental
That's part of the stop-start routine, so it looks like it may be already installed, but not enabled
bigjohnthomas wrote::? Well it can bloody keep it
Bloody tree hugging hippy stop start nonsense
I like to to start it go where I am going then stop it
loot wrote:I'm fairly sure you can turn it off at the speedo anyway can't you? Unless that's just until you lock up the van?
