push clutch to start
Postby aredee » Tue Oct 24, 2017 6:59 pm
Is it possible to override or disengage the function .it is obviously some sort of safety thing in case its left in gear but after nearly 50 years of driving i would like to think im clever enough to realize this myself
aredee
Re: push clutch to start
Postby loot » Fri Oct 27, 2017 4:47 pm
Especially as they have a 'not in neutral' gear lever switch :lol: but i think the clutch thing is more to do with stop start, although I'm sure not all vans have it.
Be interesting to know if it can be turned off, I've not seen anything obvious myself but I'm sure the info would be there.
:wink:
Ids map here
loot
Postby bigjohnthomas » Fri Oct 27, 2017 7:27 pm
Mines not got got stop start
But if you put the clutch down turn the key the engine starts to turn over .. Let go of the key ... Lift the clutch up a but .. It stops turning over then press the clutch down again and it starts on it own without touching the key :?
Batshit
Bonkers
White mouse
Mental
bigjohnthomas
Postby Altransit » Fri Oct 27, 2017 7:44 pm
bigjohnthomas wrote:Mines not got got stop start
Batshit
Bonkers
White mouse
Mental
That's part of the stop-start routine, so it looks like it may be already installed, but not enabled :? :?
Postby bigjohnthomas » Fri Oct 27, 2017 7:57 pm
:? Well it can bloody keep it
Bloody tree hugging hippy stop start nonsense :x
I like to to start it go where I am going then stop it :P
bigjohnthomas
Postby loot » Fri Oct 27, 2017 8:00 pm
Batshit
Bonkers
White mouse
Mental
Bjt only has 1 battery i think lolz Jippo :o although i am quite envious of his rear view mirror :cry:
On vehicle config it states starter stop start or standard starter i think so maybe 2 batteries and a special starter are needed?
Mine never works anyway. :roll:
Ids map here
loot
Postby bigjohnthomas » Fri Oct 27, 2017 8:14 pm
I only need one battery :P
Could do with a window switch and some tyres though :(
Bloody vans want,want want
bigjohnthomas
Postby Altransit » Fri Oct 27, 2017 8:16 pm
bigjohnthomas wrote::? Well it can bloody keep it
:lol: I know what you mean, I usually turn it off in the car as it gets annoying when it randomly stops at traffic lights etc. At least it doesn't stop if you hold the clutch down, whereas the annoying Caddy auto that my son used to have, used to stop just as you were pulling out from a junction :shock: :roll:
Postby loot » Fri Oct 27, 2017 8:33 pm
I'm fairly sure you can turn it off at the speedo anyway can't you? Unless that's just until you lock up the van? :-)
Ids map here
loot
Postby Altransit » Fri Oct 27, 2017 11:04 pm
loot wrote:I'm fairly sure you can turn it off at the speedo anyway can't you? Unless that's just until you lock up the van? :-)
It's a button on the dash in the Focus, but it resets when you stop the engine normally. It doesn't work at all if the battery is low, or failing :(
Postby loot » Fri Oct 27, 2017 11:12 pm
I think my front battery isn't good enough to engage it.
Ids map here
loot
Postby Damien89 » Wed Nov 01, 2017 11:52 am
Not a transit but could still work on our transits.
https://www.youtube.com/watch?v=Qf0dQEUg9VQ
Damien89
Postby aredee » Sat Nov 04, 2017 3:15 pm
topic of stop start seems to have taken over the post .Im on about just the starting from beginning of journey or if i stall during the trip i have to turn key off then dio clutch and turn key again
aredee
Postby man le-mans » Wed Dec 20, 2017 9:57 pm
Pushing the clutch in takes the weight off the gearbox so makes the turning over of the engine easier.
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Postby dumper » Wed Dec 20, 2017 10:18 pm
I don’t see it as much of a problem I driven over the years I have driven every thing from ride on mowers trucks buses and construction plant upto 135 ton crawler crains and even my auto TOYOTA you have to press brake pedal to start it’s nothing new to have start inhibitors the only time I find it annoying is when doing a service and have to get in to start it
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
