Mk vin numbers
Mk vin numbers
Postby dumper » Wed Dec 13, 2017 7:39 pm
Hi where do I find engine and vin numbers on 15 reg mk8 460 bus thanks
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Mk vin numbers
Postby Altransit » Thu Dec 14, 2017 10:18 pm
Passenger side lower windscreen :?:
Re: Mk vin numbers
Postby dumper » Thu Dec 14, 2017 11:20 pm
Thanks alltransit is their also one stamped into the steel work I think it is also on the vin plate what part of the engine is the engine number located on 2.2 rwd Euro 6 cheers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Mk vin numbers
Postby bigjohnthomas » Thu Dec 14, 2017 11:36 pm
Isn't it stamped in the rhs chassis leg ?
Think it is on a mk7
Might be
Might not be
bigjohnthomas
Re: Mk vin numbers
Postby dumper » Fri Dec 15, 2017 1:49 am
Someone told me there is one under the bonnet somewhere jt I know my tramps van is under the wheel arch :D :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Mk vin numbers
Postby Damien89 » Fri Dec 29, 2017 10:01 pm
Right hand side front wheel well, just in front of the shock absorber there's the vin number
Damien89
Re: Mk vin numbers
Postby dumper » Sat Dec 30, 2017 12:28 am
Thanks for that the first bus I was going to look at had to many inconsistencies looked to good to be true so ended up getting one from the auction x alphabet leasing so been through all the BCA checks so all should be ok the private seller one look good with no vat but as they say if in doubt walk away better paying the vat then loseing it afterwards
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
