Unlocking - key fob or something else?
Postby Stranga » Sun Dec 31, 2017 12:40 pm
Having issues with my remote unlocking:-
Key fob wont work at all then -
After a short drive it works for a hour or so
After a long drive it works for a few hours
I used to just open all the doors using the key in the drivers door (back twice) but now doing this only unlocks the drivers door, if I jump in and press the unlock button on the passenger door nothing happens, start the engine then press it again and it unlocks!
I am quite prepared to buy a new remote fob off ford (my original Ford fob was pretty battered and stopped working so sent it away to get refurbished by a 3rd party company and it worked fine for a couple of months) but want to be sure that its def the keyfob that's the issue and nothing else.
Any advice / suggestions welcome.
Cheers
Stranga
Re: Unlocking - key fob or something else?
Postby Altransit » Sun Dec 31, 2017 12:55 pm
Your auxiliary battery, under the drivers seat is cream crackered :idea:
Postby blue estate » Sun Dec 31, 2017 1:23 pm
Altransit wrote:Your auxiliary battery, under the drivers seat is cream crackered :idea:
I second that
72plt MG 5 ev estate Battery car
blue estate
Postby Stranga » Sun Dec 31, 2017 1:41 pm
Thanks for the quick replies
Probably no more expensive to replace than a keyfob.
I will check it out.......thanks again.
Stranga
Postby blue estate » Sun Dec 31, 2017 1:44 pm
Stranga wrote:Thanks for the quick replies
Cheaper , as you need van hooked up to computer to reprogram fob :(
blue estate
Postby D33 » Wed Jan 03, 2018 10:18 am
Hi all, having the same problem myself with my work van. 64 plate custom.
Exactly the same as the OP problems but this is the 4th time its happened and im out of warranty now.
Whats this auxillary battery under the seat you speak of?
Many thanks
D33
Postby Altransit » Wed Jan 03, 2018 11:06 am
D33 wrote:Hi all, having the same problem myself with my work van. 64 plate custom.
Many thanks
You may or may not have two batteries in your Custom, but if you do, one of them is a dedicated starter battery, and one is an aux battery that also assists with starting. If your aux battery is failing, then the electrics will play up, or not work at all, until you turn on the ignition, at which point the starter battery is switched in, ready for a start.
In a Mk7 Transit, the aux battery is the front one, under the drivers seat, but I believe that (for some reason!) it's the rear one in a Custom.
If you've had the problem several times, I would lay odds that the "repairer" charged up the failing battery and sent you on your way. It really needs replacing, and it's probably best to do both at the same time :)
Postby D33 » Mon Jan 08, 2018 4:45 pm
Thanks for the fast reply. Iv been looking and i think it only has 1 battery. Its going to be going into a proper garage and not a dealer this time. Its works van not mine but a huge pain in the arse using the safetly lock key and switching ignition on every time to opem amy door but the drivers.
Dont have any problems like this or any at all with my mk5. Id drive that over my new one any day of the week.
D33
Postby Stranga » Fri Jan 12, 2018 4:19 pm
Right heres an update:-
Both batteries have been removed and tested - both showing as alright (on 2 separate tests)
Both trickle charged till full and re fitted
Keyfob locks and unlocks doors fine after refitting
Following morning - keyfob wont work and key will only open drivers door
Any other suggestions as to what might be causing this? It has been suggested that I try getting the key re programmed but that still doesnt explain the key going from opening all doors to just drivers door.
Stranga
Postby Stranga » Fri Jan 12, 2018 4:34 pm
Update update
Been told its most likely the keyfob as the reason all the doors now don't unlock with the key is due to the latest software update (had mine done in Dec) this now only lets the key unlock the drivers door for security due because of people breaking into vans with molegrips etc on drivers lock opening all doors.
Stranga
Postby Altransit » Fri Jan 12, 2018 7:31 pm
I still say it's the batteries :mrgreen:
Postby blue estate » Fri Jan 12, 2018 7:54 pm
Altransit wrote:I still say it's the batteries :mrgreen:
Echo
blue estate
