Security flaws
Security flaws
Postby Marky s » Mon Mar 26, 2018 9:09 pm
Anyone shed any light on this Rang local ford dealer today to ask about the problems with global unlock on the drivers door lock and was told it doesn’t effect all mk8 transits just the customs I believe this to be incorrect as mine unlocks all doors if turning the key twice anti clockwise
Marky s
Re: Security flaws
Postby hectors-tranny » Tue Mar 27, 2018 9:34 am
Yes you are correct and they are wrong. Double unlocking does unlock all doors.
There is a software available now to override this. Tell them to look into it.
On the subject of security, I'm currently in the process of getting a HyKee replock fitted to my driver's door, as I understand the Mk 8 is pretty easy to break into by gripping the lock with a wrench and twisting :-(
hectors-tranny
Re: Security flaws
Postby Marky s » Tue Mar 27, 2018 6:39 pm
I’ve rang again today and they said the software is not available for my van yet they checked on etits so I’m getting it sorted with a new security barrel thou it still will unlock the back doors but hopefully put them off
Marky s
Re: Security flaws
Postby man le-mans » Tue Mar 27, 2018 8:03 pm
So if the update stops the back doors from unlocking how do you open it if the remote stops working
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Re: Security flaws
Postby RECKLESS ROAD » Tue Mar 27, 2018 10:06 pm
Marky s wrote:I’ve rang again today and they said the software is not available for my van yet they checked on etits so I’m getting it sorted with a new security barrel thou it still will unlock the back doors but hopefully put them off
they did my mk8 jumbo a few months ago when it went in for a service and I also changed my drivers lock to a hykee one after mine got broke into
RECKLESS ROAD
Re: Security flaws
Postby andz327 » Wed Mar 28, 2018 7:30 pm
Just watched a vid about this on YouTube , set of vicegrips and your in......fookin shocking
andz327
Re: Security flaws
Postby Frag » Wed Mar 28, 2018 9:44 pm
man le-mans wrote:So if the update stops the back doors from unlocking how do you open it if the remote stops working
Double press the unlock button on cab door,
Difference being,after update if you unlock door using key manually,(not with remote) or 'break in'
This function also does not work till a correctly coded (PATS) key has been used in ignition
Frag
Ford Technician
Re: Security flaws
Postby Marky s » Sat Mar 31, 2018 9:28 pm
I think I will need to go into a dealer face to face and get it sorted fed up being fobbed off as it’s not on etis but clearly it’s a problem
Marky s
Re: Security flaws
Postby hughesyn » Sun Apr 01, 2018 4:55 am
The trouble is, the scum don't know if your van has had an update or not.
I've got the update, but have fitted a rep lock anyway to avoid the door lock getting knackered by someone with a pair of grips.
Also, once in, they can get to the OBD port to programme a new key. Not so many sophisticated tea leaves around, but it is possible.
Better safe than sorry.
2023 Mk8 DCIV 170 auto L3H2
hughesyn
Re: Security flaws
Postby dumper » Sun Apr 01, 2018 10:01 am
Got replock on mine plus a disclock as a visual deterrent and hope it takes as long as the manufacturers clame I know it’s bad to lose a van and all your tools and loss of work but if you lose a self built camper you can’t just go out and replace it
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Security flaws
Postby hectors-tranny » Sun Apr 01, 2018 6:47 pm
dumper wrote:Got replock on mine plus a disclock as a visual deterrent and hope it takes as long as the manufacturers clame I know it’s bad to lose a van and all your tools and loss of work but if you lose a self built camper you can’t just go out and replace it
Which replock did you get? Did you get the rotating bezel as well? Can you give me a link?
Cheers - HT
hectors-tranny
Re: Security flaws
Postby JonR » Mon Apr 02, 2018 1:42 pm
http://www.vanlocks.co.uk/choose-your-v ... 61?cPath=&
I bought mine from there last year comes with the bezel now, mine doesn't spin but is tapered every which way, took me longer than 15 mins to fit and if you have a battery drain issue like me disconnect the battery !
I would like to secure the side door from inside as i don't use it at all, has anybody got any a wizard way of doing that before i start bodging something together ?
2014 Trend 290 econetec L2H2
JonR
Re: Security flaws
Postby dumper » Mon Apr 02, 2018 3:19 pm
Hi hector if you mean the outher part rotates then no it’s just bevelled on the out side
Cheers - HT
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Security flaws
Postby Jacob Adams » Wed Apr 11, 2018 7:47 pm
Hi all,
Here at wolf elec LTD. We have designed our new electronic deadbolt system.
Check out our Facebook page to see some videos
https://m.facebook.com/deadboltkits/
Here’s the link to our new eBay listing with the price deduction
https://rover.ebay.com/rover/0/0/0?mpre ... 2912326180
If you have any questions at all please message me or call me on 01279 411014
Hope to hear from some of you soon!
Image www.wolfelec.co.uk
Phone: 01279 411 014 Electronic Auto Accessories, Quantity Discounts, Next-Day Delivery
Jacob Adams
Registered Trader
Registered Trader
Re: Security flaws
Postby hughesyn » Thu Apr 12, 2018 7:31 am
^^^ Listing says it's for a Custom, not a mk8 Transit.
Will it fit a mk8?
hughesyn
