Transit 2013 Onward Double Seat Swivel Base
Postby Customshop Designs » Thu Mar 29, 2018 11:19 am
Here is the brand new double seat swivel base designed by the Customshop team (Community Registered Design 001382212-0001) The Ford Transit 2013 onward double seat swivel base is the only crash tested double passenger swivel base on the market. The locking points work on a unique 1/4 turn 'quick release' system so removing all 4 fixing bolts and rotating the base takes literally seconds! They are manufactured in the UK and made from 4mm laser cut steel (raises the seat by 45mm), and has passed seat belt anchorage safety tests using a pull test on a specialist test rig to EC Directive 76/115/EEC as amended by 2005/41/EEC which is a standard requirement for insurance companies when making this type of modification to your camper van and also peace of mind for transporting your friends and family around. The base allows you to rotate the double passenger seat 180 degrees and lock the seat in the reverse position to completely transform the living area in your van. Fits all Transit models from 2013 onwards and is available in Left hand and Right hand drive versions. Fixes directly to the existing floor mounts so no drilling required, installation takes approximately 40 mins from start to completion.
Regards
Customshop
They can be purchased from any of the links below.....
https://www.customshopdesigns.com/copy- ... -transit-c
eBay listings
Customshop Designs
Registered Trader
Registered Trader
Re: Transit 2013 Onward Double Seat Swivel Base
Postby Customshop Designs » Tue Apr 10, 2018 1:39 pm
We have had one or two customers asking about the operation of the double seat swivel so we have uploaded a few clips on youtube to help anyone out. If any further advice is needed regarding fitting or operation then don't hesitate to give us a call on 01254 230300 and we will be happy to help.
Seat swivel operation - https://youtu.be/U3K4i6WYnHo
Reverse alignment and locking - https://youtu.be/5ddE4QiQ8KM
Locking pin operation - https://youtu.be/o3HnYRWmMY0
Customshop Designs
Registered Trader
Registered Trader
Users browsing this forum: Google Adsense [Bot], theoTD
